3" stainless Downpipe
MikeDanger
PostPosted: Wed Jul 07, 2021 2:27 pm    Post subject: 3" stainless Downpipe Reply with quote
Working on the DP, mandrel bent tubing, being done by Hanksville: http://hanksvillehotrods.com/
Now waiting on the turbo and couple other factors
PostPosted: Wed Jul 07, 2021 9:07 pm    Post subject: Reply with quote
Very sexy!
What did you use for the turbo flange, did you cut off an old one or start from scratch?
PostPosted: Thu Jul 08, 2021 1:46 am    Post subject: Reply with quote
Nice! Hows the space against the surrounding stuff? And the nuts on the flange for example? Will you attack the wg line as the stock exhaust?
PostPosted: Thu Jul 08, 2021 2:00 am    Post subject: Reply with quote
Oooohhhh...
Remember an O2 sensor bung (or 2), and ask about how much for more copies
MikeDanger
PostPosted: Thu Jul 08, 2021 1:56 pm    Post subject: Reply with quote
We used a stock flange, just to tack to it for placement, The turbo I'd like to used has a 3" V-band. For the stock turbo there would have to be 3-2.5" stepdown
there is actually more clearance with this pipe than the factory. With the stock pipe its too close to the J pipe, so you have to remove the J pipe before you can pull off the down pipe. (because the DP has to move backwards to clear the studs on the hotside, and it hits the J pipe) We adjusted so there is more room.
The turbo I want has an integrated WG and BOV
