New Porsche 924S owner
Porsche924Me
PostPosted: Mon May 24, 2021 11:25 pm    Post subject: New Porsche 924S owner Reply with quote
Hi all. Been lurking around the forum a few weeks and finding some helpful info on the threads and as a first time Porsche owner thought I would sign up and introduce myself as I will have some questions to come
My name is Martyn. Car enthusiast as I expect we all are here. Love Jap and German cars mainly, having owned a couple BMW Z3s and a Skyline at one point, currently owning a Nissan 350z as my every day car I’ve been wanting to buy a classic / little bit of a project for weekend and pleasure use
I’ve been eyeing up the Porsche 944’s for a few years, was going to buy one off a friend that unfortunately he has left to rot on his drive for the past 7 years but he wants too much for it considering the amount of work it needs unfortunately. Then I came across this 924s and other than a faded bonnet and a faded roof with a bit of work needed here and there she seems mechanically sound, not much rust considering the age (little bit near front passenger sill and looks to be some hiding behind the driver side rear spat) but I’m in love with it. It’s listed as black but it’s almost a slate black, whatever it is I really like the colour and would like to restore it to the same if it turns out it is a factory colour
Thanks in advance for any future help with my questions / car niggles to come !
First one is, does anyone recommend any preventative work / checks to start with?
Pictures available here:
https://photos.app.goo.gl/73SUj5c9mVwVezU88
Jap and German Car Enthusiast
PostPosted: Tue May 25, 2021 12:16 am    Post subject: Reply with quote
Nice!!
I like the color a lot too!
Welcome!
PostPosted: Tue May 25, 2021 1:34 am    Post subject: Reply with quote
Greetings!
Do you know the service history on the car? If the timing belt is of unknown age, you should plan on replacing soon. . .a great way to drive into the 2.5 platform.
Porsche924Me
PostPosted: Tue May 25, 2021 7:33 am    Post subject: Reply with quote
Greetings!
Thanks for the welcome guys and the advice on thing to check for first definitely appreciated
I have some history for the vehicle, There is a receipt from Dec 05 (about 35k miles ago) with :
-Timing belt
-Balance belt
-Timing belt pulley
-Roller pulley
-Roller
-Balance belt pulley
...Also Clutch Kit for £343
Would you recommend doing again? It does have a funny start sometimes. Sometimes it starts up fast and easy. Sometimes it struggles but then starts. It’s started every-time and once it’s going it idles perfect just sometimes has a strange lag to start, not sure how to explain it
PostPosted: Tue May 25, 2021 2:36 pm    Post subject: Reply with quote
16 years ago? If it were me I'd park it and start ordering parts.
Porsche924Me
PostPosted: Tue May 25, 2021 4:36 pm    Post subject: Reply with quote
Yep have done, it’s not my daily. Going to service it, flush the radiator etc as well before I start using it for weekend cruising.
Any other preventatives to look at as a priority ?
Thanks for the advice
PostPosted: Tue May 25, 2021 5:10 pm    Post subject: Reply with quote
With a 15 year old timing belt it’s seriously a time bomb..
I wouldn’t even start it at all..
Porsche924Me
PostPosted: Tue May 25, 2021 5:11 pm    Post subject: Reply with quote
Duly noted, will be the first thing to do ASAP
PostPosted: Tue May 25, 2021 11:07 pm    Post subject: Reply with quote
Paragon has a nice belt and roller kit along with a front seal kit with collars. . .
Porsche924Me
PostPosted: Wed May 26, 2021 12:35 am    Post subject: Reply with quote
Thanks for that. Just had a look, sadly looks like it’s US only, I’m in the UK. Have found this kit though https://www.design911.co.uk/fu/pt178_237_-cma81-cmo83-ct323/Porsche/924-1977-88/924S-2-5L-1986-87/Belts-for-Alternator--Fan--Power-steering-etc-/#3212
PostPosted: Wed May 26, 2021 3:31 am    Post subject: Reply with quote
That belt kit looks great.
Here's the seal kit:
https://www.design911.co.uk/fu/prod127033/Engine-Timing-Dust-Seal--Gasket-Set-Porsche-944--968/
You also need this:
https://www.design911.co.uk/fu/prod144751/Front-main-crankshaft---oil-pump-seal-Porsche-944---84_2/?source=doofinder
This:
https://www.design911.co.uk/fu/prod128826/Oil-Pump-Toothed-Sleeve-Porsche-944-1982-85-94410716101/?source=doofinder
This:
https://www.design911.co.uk/parts/99970728340/?source=doofinder
You should also replace water pump and thermostat.
Are you doing this yourself? There are a few special tools as well, like a flywheel lock, some special thin spanners and a tensioning tool.
Porsche924Me
PostPosted: Wed May 26, 2021 9:01 pm    Post subject: Reply with quote
Brill thank you for your help! Tbh I’m going to take it to my local mechanic. Usually do things I can myself but with something as important as belts I don’t want to risk making a mistake
PostPosted: Wed May 26, 2021 11:11 pm    Post subject: Reply with quote
K, just make sure this isn't the first one they've done...there are a few tricks and things easily overlooked in this job.
Porsche924Me
PostPosted: Wed May 26, 2021 11:37 pm    Post subject: Reply with quote
Will do, I gave him a call a couple days ago checked it would be something he would feel comfortable working on and he was quite enthusiastic as he used to have one so should be in good hands. But if you’re willing to provide a little tips list I will give him a heads up
Thanks again
PostPosted: Thu May 27, 2021 12:24 am    Post subject: Reply with quote
Everything needed is here:
http://www.clarks-garage.com/shop-manual/repair-procedure-index4.htm
If you are committed to the car, you should consider resealing the balance shaft housings and oil cooler housing as well. The latter is especially important because a failure here could lead to bearing damage.
These motors can be quite leaky, and it is best to get them sealed up well. Once done, you should be good for 100k miles.
