Stage 1
PostPosted: Wed May 12, 2021 6:45 pm    Post subject: Reply with quote
I see from some 911 forums that some injectors will flow a small amount more than others given them being in the same same fuel distributor, but I’m pretty sure that if their is enough fuel distributor flow it will just blast right through the injectors, like the GTS does..
Maybe it’s that some injectors are slightly more restrictive than others, but I think they can all just flow basically whatever is pushed through them, +- a few % of eachother..
injector C2 3.3 turbo : bosch 0437 502 017 Porsche 931 110 225 00
Flowed qty per 60 sec : 270 gr
injector C2 3.6 turbo : Bosch 0437 502 057 / Porsche 964 110 235 20
Flowed qty per 60 sec : 285 gr ( at least)
The specific gravity of gasoline @ 60°F is 0.739 so your flow would be:
-017 injectors @ 270g = 365.4 ml/min
-057 injectors @ 285g = 385.6 ml/min
About a 5.5% increas in fow for the -057 over the -017 if standard deviation is very low.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/621594-wrong-fuel-injectors-my-car.html
On some 911 fuel distributor..
But small variances between injector flow on the same fuel distributor I don’t think sets a limit on what the injector would flow if supplied more fuel from a different distributor..
I.e. The GTS can slam more fuel through the same OEM 931 injectors (017) by just supplying them more fuel..
PostPosted: Wed May 12, 2021 7:21 pm    Post subject: Reply with quote
Fasteddie313 wrote:
Hey Cedric, would some $$ get that lower charge tube printing faster?
Probably should make atleast 3..
I also have a tunable US fuel distributor with most of the frequency valve setup for you if you want it..
Known working and will bolt right on.. Just add a microsquirt..
Will tune exactly the same way as my V8 one, except it doesn’t need any other external DPR controller, but won’t do complete fuel cut..
(I’ll talk someone into trying it eventually)
The design is more or less done on that, took some help from a friend who worked for years designing cast boost pipes to finish om my design. The thing im not settled on is the assembly options, at the moment the plan is to integrate steel nuts in the print. But its a risk that it will never work with only 2 screws for the flange, thats the biggest challenge i think
I probably don have time to take my car appart and experiment, at least not for a while. Would you want to try one if i print it?
The US dizzy is something ive thought about, especially since the turbo could supply a fair bit more than the fuel system can supply, but it do add wiring and some sensors which always is a drawback, do you read RPM to the Micro via tachsignal?. But i need to evaluate the power level where im at now also, and for that i need more track time. I need to see if its thermally stable on track with regard to water and oil cooling, how other things hold up like brake system, tyre setup, ignition system and knock stability etc etc. Road and track is two massively different subjects when it comes to power levels.
safe
PostPosted: Thu May 13, 2021 12:16 am    Post subject: Reply with quote
I'm very sceptical that the stock fuel distributor will support 300hp, not without modifications. I would also think that the fuel pump is getting very near its limit too.
Any dyno sheets to support this statement?
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
PostPosted: Thu May 13, 2021 2:34 am    Post subject: Reply with quote
I think there might be some values that are a bit of here, 0.5 BSFC is around 300g/kWh according to the convertor (im lazy). I can guarantee you that our old overfueling knock sensitive engines are not close to that on full power. So will most likely affect the predictions quite a bit. Would be fun if someone tried it though to see what it could deliver, actual HP will depend alot on other stuff though, like turbo matching and ignition timing etc.
PostPosted: Thu May 13, 2021 12:55 pm    Post subject: Reply with quote
Might not be so overfueling and knock sensitive if you run a good IC and are able to tune your AFRs so you aren’t running pig-rich..
I think this engine is a tank.. Supposed to hold the cylinder pressures/torque of a diesel..
I suppose you wouldn’t think that going off the experience of non-intercooler engines, untunable CIS that is doing who knows what, the time before widebands, etc..
That’s what it’ll flow, whatever power that would make would have to be tested/measured..
Probably will never be tested because nobody will ever do it..
I’ve never measured the power I’m making either, have no idea, I know it pulls very hard though and makes my M3 feel like a turtle..
I’d like to dyno some time.. Might get around to it, but I just use big hills and sometimes my brakes to street tune.. I can even have someone else drive and say “hold 4000 RPM and 13psi, now 4500, now 5000, now slow down and do the same thing at 17psi”.. Can do static tuning all day long that way on long straightaways usually in 4th gear and make it do whatever I want..
Don’t really need to dyno for anything, and whatever numbers it would give would be “dynos are inconsistent” anyway..
Cedric I’d definitely try one but who knows when..
I’ll be lucky to find time to just install my new injectors and see what that does.. Might need some slight retuning..
Might use black RTV and just glue that lower charge tube connection instead of relying on just a gasket..
I’m not sure if I’d even notice a little boost leak there though because I’d just end up tuning around it.. Unless it was big enough to notice I’d probably never even know..
I’m sure track conditions are harder on thermal management.. Probably should see if you get any cooling issues.. You might..
Yeah just tach signal.. It can tell RPM that way but not crank position..
Doesn’t matter “constant injection”..
Would need a real signal for ignition..
PostPosted: Thu May 13, 2021 3:50 pm    Post subject: Reply with quote
Get it dyno’d....... .
From my experience your butt cannot tell the difference between 200 and 250rwhp. Both feels quick in a 924.
safe
PostPosted: Thu May 13, 2021 4:03 pm    Post subject: Reply with quote
I dont doubt that it is a stout engine or the tuning you can do on the streets. I doubt that the kjet can deliver the required fuel.
Remove an injector and meassure what it can deliver at maximum plate lift.
Porsche 931 -79
PostPosted: Thu May 13, 2021 7:44 pm    Post subject: Reply with quote
That is exactly what I did..
safe
PostPosted: Thu May 13, 2021 7:45 pm    Post subject: Reply with quote
The result?
Porsche 931 -79
PostPosted: Thu May 13, 2021 7:46 pm    Post subject: Reply with quote
safe wrote:
The result?
It’s on the previous page..
164 grams per 30 seconds = 438 cc/min or 41.7 lbs/hr
good for approximately 330HP at 0.5 bsfc
safe
PostPosted: Thu May 13, 2021 7:53 pm    Post subject: Reply with quote
Cant decipher who wrote what.
438 cc meassured?
Then 300 is possible in theory, but has boost preassure been detracted from the fuel preassure?
Porsche 931 -79
PostPosted: Thu May 13, 2021 8:14 pm    Post subject: Reply with quote
Well, reducing fuel pressure by about 14%/14psi only reduced fuel flow by about 2.8%..
Sooo.. Could it be assumed that the inverse is also true?
Also, stock fuel pump seems adequate to quite a bit more than what I expect a stock FD to do..
PostPosted: Fri May 14, 2021 1:55 am    Post subject: Reply with quote
All guess work until its proven on the dyno.......... which I did and hit 268bhp estimated to crank, limiting to 6000rpm, 1.1bar, and fuel delivery of circa 360cc/min. Probably could have gotten more if rev'd out further, more boost etc. etc, but this a safe place for AFR's and detonation for my car and end use.
PostPosted: Fri May 14, 2021 9:00 am    Post subject: Reply with quote
In any case, aside from theoretical maximum limits, I believe we can all agree that adding an intercooler greatly increases reliability/durability against any possible tuning mishaps, and then adding boost on a decent tune will make HP #s become larger..
I live out in the middle of nowhere and when I contacted the closest dyno shop they wanted nothing to do with my contraption and recommended that I just street tune it.. So I have..
Their is one other place relatively close with a dyno but they specialize in diesel pickup trucks.. Deisel freaks..
Maybe I could use their dyno just to get some numbers but I don’t find it extremely important..
I have been in my home state for about 17 days total this year.. I am going to take some time off soon but I’m looking to book a sailing charter on Lake Superior.. (To somewhat advance another one of my pipe dreams)
Like I said.. If I even get around to installing my new injectors and doing some testing after that, I’ll be lucky as far as Porsche time goes..
For now, I have time for reading, writing, and parts accumulating..
PostPosted: Fri May 14, 2021 10:10 am    Post subject: Reply with quote
Shouldn't matter what vehicles the dyno shop specialise in, you just want an hour of their time to strap your car down and run 2-3 pulls.......get some data + a bhp/torque print out and then get outta to the shop smiling with big numbers
As for importance.......apart from bar room bragging and willy waving on forums , its just really good to confirm the time and money invested is getting you near or over your goals.
Page 2 of 4
