1 stud build
Goto page Previous  1, 2, 3, 4, 5
Juho
PostPosted: Sat Jun 27, 2020 7:33 am    Post subject: Reply with quote
This is how inspection went, lol
Juho
PostPosted: Fri Oct 02, 2020 10:22 pm    Post subject: Reply with quote
Fixed the altenator mounting today so i could drive it again. I need to replace rear drums because when i took a wheel off the threads came out too.. And i still got a lot of stuff to do for inspection like making it leaner, headlights point too up, and get paperwork for coilovers. Really hard to work on the time because im in military atm.
safe
PostPosted: Fri Oct 02, 2020 10:47 pm    Post subject: Reply with quote
I like the white wheels!
Juho
PostPosted: Fri Oct 02, 2020 11:17 pm    Post subject: Reply with quote
i want different wheels to get better fitment on the back and also install turbo mudflaps because they make rear look so much better
safe
PostPosted: Fri Oct 02, 2020 11:33 pm    Post subject: Reply with quote
Spacers on the rear would look nice!
Hard to find turbo mudflaps in good condition. The mounting studs are usually rusted out.
Ratbikerich
PostPosted: Tue Oct 13, 2020 9:01 am    Post subject: Reply with quote
I ordered a manifold from Danstengineering that looks like what you are using here. Great write up and can’t wait to install my yzf600r carbs. I have a question for you: what did you use to block off your injector ports?
Juho
PostPosted: Sun Oct 18, 2020 3:03 pm    Post subject: Reply with quote
Metal plugs and silicone ot something
PostPosted: Mon Oct 26, 2020 3:36 am    Post subject: Reply with quote
The fuel injector port plugs are a 24mmx1.5 pipe plug. The are available from McMaster-Carr, metric-thread.com, possibly on ebay. At MC not cheap about $10 each, get the ones that are put in with a hex key, and external head probably won't clear the head.
Mike
'77 924
cricketdesigns.com
Ratbikerich
PostPosted: Thu Nov 12, 2020 8:48 am    Post subject: Reply with quote
Perfect. I just ordered them from MCMaster. Thanks!
Page 5 of 5
