Driveline Install
PostPosted: Sat Oct 17, 2020 1:49 am    Post subject: Driveline Install Reply with quote
I've always wanted to install the entire driveline as an assembly, factory-style, and I finally did it.
It was ridiculously easy with a jack under the trans and a cherry picker raising the engine. For a serious restoration project, I think I'd recommend the procedure as the standard approach.
PostPosted: Sat Oct 17, 2020 5:08 am    Post subject: Reply with quote
Please detail!
I’ve always wanted to more like lift the body off, but how did ya do it?
kondzi
PostPosted: Sat Oct 17, 2020 7:29 am    Post subject: Reply with quote
Photos / Videos please
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Sun Oct 18, 2020 3:54 am    Post subject: Reply with quote
Sorry, no pics. Ever since Photobucket screwed the universe, I've stopped documenting projects like I used to.
The process was easy...I raised the tub on for a jack stands as high as it would go. I then slid the engine under the nose of the car and bolted up the torque tube to it, with a little bit of help from a floor jack raising the transmission end. I then bolted on the gearbox.
Once everything was together I raised the engine end of the assembly with a cherry picker and raised the transmission end with a floor jack. It was ridiculously easy.
931-1979
PostPosted: Mon Oct 19, 2020 4:11 pm    Post subject: Reply with quote
I did it on this way:
https://www.youtube.com/watch?v=GQRQm1Cj5Ic
David
924 2,0 - 1982
jacobroufa
PostPosted: Tue Oct 20, 2020 3:35 am    Post subject: Reply with quote
O_O Wow that's cool. Sure looks simpler to drop/reinstall the whole kit and kaboodle than to deal with each part separately, contorting hands and limbs to get those last two upper bolts...
1980 Porsche 931
1981 Porsche 924 Weissach
PostPosted: Sat Oct 24, 2020 6:22 am    Post subject: Reply with quote
Indeed, and so much easier to align the clutch when the engine and tube are on the ground.
