1980 924 starting issues CIS Injection
vdub6v
PostPosted: Sat Sep 19, 2020 7:59 am    Post subject: 1980 924 starting issues CIS Injection Reply with quote
2.0L Audi motor, regular 924. Not a 931 Turbo. The car hasn't "ran" since I got it. As far as I know it hasn't ran since 1996. New fuel filter, flushed tank, everything was incredibly clean.
With the WUR either valved off or in series with a pressure gauge I get the following: the gauge applied to the center of the fuel distributor, the pressure climbs to 5 bar (~75psig) while it is running and drops to 3 bar ( ~ 45psig) when it stops.
The car fires up strong (fraction of a second) but will only remain running if I give it gas/hold the throttle body open.
I replaced the intake boot because it was ripped near the auxiliary control valve connection. Still no resolve. I also purchased a known good fuel distributor and installed it. Still no resolve.
Starting - no gas
https://photos.app.goo.gl/ppfSaHEZoBdXVt3H7
Starting - giving it gas (ignore the squealing blower fan)
https://photos.app.goo.gl/oP2tF1LY7tZy1mr7A
What should I be looking for next?
Witty924
PostPosted: Sun Oct 04, 2020 10:07 am    Post subject: Reply with quote
Hey there.
So the pressures look good on running for you WUR. But itís the start not holding the revs makes me think your WUR could have a blockage. These things need to be ultra clean. Itís worth removing and cleaning the intake and outtake with cleaner. Next you need to look at the airflow meter. Take the air filter out ask someone to start the car while you lift the airflow plate with your hand, if it fires and stays running with your hand lifting it then you need to recheck the WUR as above as there is an issue with fuel pressure.
Do the air flow meter test before you take the WUR off as a starter. Also check and clean the airflow meter plate, they can get clogged and become sticky, they should be spotless. Check out my vids on the above at witty 924 on YouTube. Hope it helps resolve the issue
Witty924 - Porsche 924 2.0l NA 1984
vdub6v
PostPosted: Wed Oct 07, 2020 11:17 am    Post subject: Reply with quote
thanks brother, I will check it out. Since it runs the same with the WUR blocked off or inline, I think you conclusion is a likely one.
I will check out your videos and let you know what I come back with.
