emhewitt
Posted: Sat Sep 26, 2020 12:28 am Post subject: 931 spark plug change |
My mechanical expertise is limited to things that easily screw or unbolt easily. In this case, those qualifications are falling short....How can I get a spark plug wrench the hard to reach plugs on my 1981 931?
Thanks
Michael _________________ Michael Hewitt |
Joined: 10 Dec 2006 Posts: 809 Location: Noosa Heads QLD Australia
Posted: Sat Sep 26, 2020 12:35 am Post subject: |
Do you have the factory toolkit which came with the car? Excellent plug remover in there. Otherwise normal plug socket and several joints (wobblies). _________________ 80/81 932/8 ROW |
chuck21401
Joined: 20 Feb 2005 Posts: 322 Location: Annapolis, MD
Posted: Wed Sep 30, 2020 12:04 pm Post subject: |
I removed the charge tube when I changed the plugs in my 931. At little extra work but less frustration with the plugs that are not easy to reach. Of course stick a rag in the lower pressure pipe to prevent anything from falling into the turbo. Also be sure to set the spark plug gap to spec...then tighten the plugs to torque spec. _________________ 1981 Porsche 931
Posted: Thu Oct 01, 2020 1:08 am Post subject: |
The original tool is really great.. It’s not super fancy or anything but works perfectly.. I pull my plugs quite a bit.. Currently BR9ES..
I also always try to blow the spark plug wells out with compressed air before changing the plugs because dirt can get in there and stay.. _________________ 80 Turbo - Slightly Modified |
