Intermediate Shift Linkage Disassembly
agfisher
PostPosted: Mon May 25, 2020 12:18 pm    Post subject: Intermediate Shift Linkage Disassembly Reply with quote
Anybody know how to take this thing apart to clean and replace the bushings?
I'm trying to remove the red circled part from the blue circled part. I can get the nut (5) off and the washer (11) comes off. Sealing ring ( comes off but then the red unit is immobile. It moves on the pin so it's not frozen. It just doesn't want to move. Has anyone taken one of these apart?
1977 924 N/A Martini Edition
PostPosted: Mon May 25, 2020 9:49 pm    Post subject: Reply with quote
I've had that apart but only with tranny off the car. An outfit called 944 Only has a replacement linkage for that for about $50 which I have on the track car which gets rid of the bushings and uses rod ends. He also had directions as to how to get in there to replace it. I think he used a cutoff 17mm wrench to get in there due to the tight space. If you would put a jack under the trans and loosen the hangers it might rotate down a bit to get a little more room. Good luck
Mike
'77 924
cricketdesigns.com
PostPosted: Mon May 25, 2020 10:14 pm    Post subject: Reply with quote
I just looked 944Only up and he is out of them. He used a 11mm wrench about 1" long. Does have some directions on the site which might help. I need to pull the gas tank as I have a bad leak, probably the normal crack and was going to get one.
Mike
'77 924
cricketdesigns.com
agfisher
PostPosted: Mon May 25, 2020 10:52 pm    Post subject: Reply with quote
Transmission is out of the car as part of a fuel tank rebuild. Also, I have a 4 speed which I don't think works with the conversion.
My problem is that the piece just dont seperate. Almost like they have been pressed together but they freely move. It's strange.
Adam
