Oil with ZDDP
ted von Kampen
PostPosted: Fri Mar 27, 2020 10:06 am    Post subject: Oil with ZDDP Reply with quote
I have a 1981 Porsche 924 2 liter NA car. Although this is an overhead cam engine, does someone have a recommendation for an oil type that has sufficient level of ZDDP to protect the camshaft?
Thanks
Goldwolf
PostPosted: Fri Mar 27, 2020 12:06 pm    Post subject: Reply with quote
Motul Classic was recommended by my mechanic
1981 Weissach Edition #179
Savethe924.com
TJC
PostPosted: Sat Mar 28, 2020 1:10 am    Post subject: Reply with quote
There may be may be many suggestions and although they are usually made with the best intentions one is wise to do their own follow up and contact the manufacturer's tech department to see if they agree.
Not trying to be a smart ass here but having built many an engine over the years and actually working in a high performance/racing engine machine shop in addition to my other auto racing/restoration experience allows me just enough of a level of arrogance to make me think my suggestions are qualified!!!
Having said that, if you want to stick with a "conventional" oil many are fond of Valvoline VR1 Racing 20W50 and Brad Penn (formally Kendall) and even Castrol here in the States. Motul and Porsche Classic are also possibilities. As far as synthetics go Mobil 1 Euro formula is a favored choice.
It's important to understand the whys and wherefores of the need for "ZDDP" in these engines and that would take a book to fully explain but basically it is a component that makes certain moving parts in an "old" tech engine happy. Why they got away from using it is another matter and involves of course "new" tech and the fact that too much "ZDDP" can affect catalytic convertors, etc.
In any event do your own due diligence, it's your engine and no one cares for it more than you do since you have to pay for any "mistakes". Good luck and have fun with your research!
'95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com
PostPosted: Sat Mar 28, 2020 5:36 am    Post subject: Reply with quote
I use Rotella T 15/40 diesel oil in all my flat tappet engines.
1979 924 NA race car
1982 924 Turbo almost a PoS
Raize
PostPosted: Sat Mar 28, 2020 5:44 am    Post subject: Reply with quote
I use the cheapest 20W-50 mineral oil and put the money I save aside for an eventual new camshaft and lifters*. Worked for the past decade...
*in an ideal world where it didn't cost more than another 924 engine or ten
anthonimartini
PostPosted: Sun Apr 26, 2020 4:59 am    Post subject: Reply with quote
valvoline vr1 is the goto in the united states. brad penn is probably the best. at my shop (avant garde collection) we use total racing 20-50 in all the air cooled porsches and anything with an older engine design. although we use brad penn in our personal cars. fyi brad penn is available for pretty cheap in bulk on ebay.
saving a 1977 martini ... please help!
PostPosted: Wed Apr 29, 2020 7:22 am    Post subject: Reply with quote
Brad Penn 20W50
PostPosted: Wed Apr 29, 2020 7:46 am    Post subject: Reply with quote
I'm putting Rotella T6 in just about everything these days..
Put quite a lot of miles on it last summer and ran it hard..
Didn't explode..
Running great right now too..
dogleg5
PostPosted: Thu Apr 30, 2020 5:30 am    Post subject: Reply with quote
Every one seems to like the heavier weight oils for this engine, even the previous owner of my car used 20/50. The owners manual has a whole range of weights for various temp ranges. I used to run 20/50 back in the 70"s. I can understand the 50 part bot wouldn't you want a thinner 10W for start ups? And I don't think any one mentioned synthetics. I would think the added protection of a synth would eliminate the need for ZDDP, no? If it's that important, I believe STP additive still contains it, and isn't it available as a stand alone additive?
PostPosted: Thu Apr 30, 2020 5:42 am    Post subject: Reply with quote
If you look at the owners manual, 20W50 has broad range of coverage except in really cool climates. If you live in a cooler climate like I do, and IF you drive your car in the winter, which I no longer do, then you might consider 10W40 for the cool half of the year.
These engines tend to run hot, especially the Turbos. The 20W50 is best, IMHO. Brad Penn is a partial synthetic. Full synth or synth blend obviates the need for a thinner oil for startup.
With as few miles as I drive mine, I put BP20W50 in, and change it every couple of years. My situation is different than most, though, as my fun driving gets spread around multiple cars, so my cars rarely see more than 1500 miles a season these days.
CÚdric
PostPosted: Thu Apr 30, 2020 5:46 am    Post subject: Reply with quote
20w is not good for oil flow during start up of course, if you live in a hot place its less of a problem. Before the season is over it still can get freezing here, so i won't put it in my car. But its an oil thread so there will be many opinion and answers
Ive ran 5w40, 5w50, 10w60 and now im back to 5w50 mobil 1 if i remember correctly. If you don't do any track driving or similar a 5w40 would probably be better. Especially for a NA car.
┤80 924 Turbo
dogleg5
PostPosted: Thu Apr 30, 2020 6:22 am    Post subject: Reply with quote
OK. Was just wondering if there was a specific reason pertinent to this car for 20w50. No turbo, don't track so I'll probably go with a 10w40.
I've used a lot of different brands and weights over the years, in a lot of different vehicles and the only issue I ever had is with my 06 Civic Hybrid that spun a rod bearing running 0w20 Mobile1. Can't say for sure it was the oil or just bad luck, but Mobil1 is off my list, just in case.
