Injector question.
MikesCoupeGT
PostPosted: Mon Apr 27, 2020 5:30 am    Post subject: Injector question. Reply with quote
Injector question. I think my injectors (or at least 2) are bad. I keep fouling cylinder 2 and 3 when I run the car hard. I am going to swap the injectors around and run it to see if the cylinders (spark plugs) foul with the injectors moving. That being the case, Does anyone know if I would get more or better flow if I buy 924 Turbo injectors for my car, or do they all flow the same?
Hope all are staying safe and taking care of yourselves and families
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
Raize
PostPosted: Mon Apr 27, 2020 10:50 pm    Post subject: Reply with quote
In my experience they all flow the same. I tested flow with no injectors on the end of the lines and it was exactly the same as with the injectors on.
PostPosted: Mon Apr 27, 2020 11:12 pm    Post subject: Reply with quote
They're hardly interchangeable... and I'm fairly sure the Turbo ones are much more expensive too...
'79 924 #77 ITB racecar
MikesCoupeGT
PostPosted: Wed Apr 29, 2020 11:32 pm    Post subject: Reply with quote
Thanks for the input. I will be out shopping for some new injectors then. Or maybe see if mine can be rebuilt. I had the ones for my 944 rebuilt, so it is not out of the question. It is all about cost.
Keep safe and healthy everyone.
Cheers;
MikesCoupeGT
'76 924
'83 944
PostPosted: Thu Apr 30, 2020 12:12 am    Post subject: Reply with quote
Turbo ones are threaded, NA ones are just push in..
IIRC their has not been much success in rebuilding or cleaning them..
