felix83
Posted: Thu Apr 23, 2020 4:45 pm Post subject: Found a mysterious relay... |
Yesterday I found this relay in the battery box. The wiring going to it looks like it could have been done at the factory, but what does it do? The car has been on SORN since 2008 and I bought it a couple of months ago.
Edit: It's a 1977 Euro car.
_________________ Felix
'77 924
'82 911 SC
Instagram: @orebro.classics | @924.resurrection |
dogleg5
Joined: 01 Apr 2020 Posts: 29 Location: No longer with us
Posted: Sat Apr 25, 2020 11:57 pm Post subject: |
Weird. I've tried searching both the numbers on the relay and nothing. My guesses are, headlight washers, security system, fog lights.
You could try starting the car and turning everything on and then unplug it and see what stops working. If the car dies, then you know it's something with fuel or ignition (which could be security system if you have that). |
Nobbi
Posted: Sun Apr 26, 2020 4:39 pm Post subject: |
Hello,
that relay is factory solution for the hot-start issue.I am not sure how it works but it builds up fuel pressure in the lines.
Nobbi _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1969 |
felix83
Posted: Tue Apr 28, 2020 5:21 pm Post subject: |
Nobbi wrote: | Hello,
Nobbi |
Thanks! The engine starts fine without it (The ground cable had come off) but I haven't tested how well it starts when warm so that might very well be it. I traced the cable back, and it connects to a sensor at the back of the engine block. _________________ Felix
'77 924
'82 911 SC
Joined: 29 Jul 2001 Posts: 8816 Location: Royal Oak, MI, USA
Posted: Tue Apr 28, 2020 9:09 pm Post subject: |
That sensor is probably the thermo time switch? Back of the head?
Or is it a 2-prong switch in the coolant line under the ignition coil? _________________ Vaughan Scott
