Fuel not getting to the injectors
Goto page Previous  1, 2
!tom
PostPosted: Sat Apr 25, 2020 10:32 am    Post subject: Reply with quote
Perhaps the Warm-Up-Regulator, which adjusts the control pressure to enrich the fuel mixture when the engine is cold needs attention.
78 924 NA
5-lug
dogleg5
PostPosted: Sat Apr 25, 2020 10:59 am    Post subject: Reply with quote
The control pressure regulator is supposed to allow more fuel to flow back to the tank on startup so that the plate can open slightly and allow fuel to the injectors. If this doesn't happen the plate can't open. There's a screw on the top of the fuel distributor that is the control regulator. I would remove that and see how many shims are in there between the screw and the spring (find a diagram online). I believe normally there is one shim. More shims=more pressure against the plate. So maybe check that out.
https://photos.app.goo.gl/rE4dYUZXek5eWH5bA
Page 2 of 2
