Posted: Thu Jan 09, 2020 11:04 pm Post subject: Brake Fluid Change? |
I have Motul RBF600 in the race car brake system, do I need to change it out completely over the winter or will just a thorough bleeding suffice? I'm also de-glazing the pads between race weekends. _________________ Mike
'67 MG Midget Dp
Posted: Thu Jan 09, 2020 11:15 pm Post subject: |
For your kind of use I would do it (I did when i tracked reaguarly) every winter. If you do it correctly it just about works with a 0,5l can of RBF600 to get all the old fluid out, so its not very expensive.
Thanks to some US law of stupidity you cant buy ATE racing blue any more. Otherwise altering between the blue fluid and RBF600 was a brilliant way of knowing when the old fluid was flushed out. But at least I learnt that 0,5l is enough to completely change the fluid _________________ 1980 924 Turbo
Posted: Fri Jan 10, 2020 4:03 am Post subject: |
I do a complete flush of the 600 every year. For a few years, I added a tiny bit of food coloring to the clear new fluid to be able to tell when the old fluid was gone and then the next year just use the clear until the colored fluid was gone. Maybe that's why when I hit the brakes I smell cupcakes _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Posted: Fri Jan 10, 2020 11:13 am Post subject: |
OK, will do _________________ Mike
'67 MG Midget Dp
Joined: 29 Jul 2001 Posts: 8804 Location: Royal Oak, MI, USA
Posted: Fri Jan 10, 2020 10:48 pm Post subject: |
I flush every year, regardless of usage. _________________ Vaughan Scott
