Dltfam51
Posted: Sun Jan 05, 2020 5:14 am Post subject: 1980 924 power booster (all disc brakes 5 lugs) |
My power booster needs replacement cant seam to find one . I was wondering if this car used a 944 booster.
1980 924 all disc brakes 5 lug wheels. |
Joined: 08 Jun 2010 Posts: 1014 Location: Maysville, Colorado
Posted: Sun Jan 05, 2020 8:10 am Post subject: |
Measure your booster diameter. The 944 is a 9" dia, many of the 924 are 7". The 944 booster assembly is longer also(with the fire wall spacer) protrudes from the firewall further. I have a 9" in the track car and had to relocate the throttle cable due to interference with the larger booster. _________________ Mike
'77 924
cricketdesigns.com |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Tue Jan 07, 2020 6:28 am Post subject: |
I just replaced mine last year or the year before that. It was difficult to find. I eventually bought one from Rockauto that was a remanufactured unit. It works nicely however when they reassembled the booster they slightly rotated the two halves from the proper orientation. My master cylinder sits at a slight angle now. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
