Blown 924 2.0 head...anything else work on the 2.0?
JaySilver
PostPosted: Wed Nov 20, 2019 5:32 am    Post subject: Blown 924 2.0 head...anything else work on the 2.0? Reply with quote
Hey folks, we blew up the head on our 924 in our last LeMons race...
Seems like the car doesn't run long without water being pumped through the motor.
We want to sell the car and move on, but we'd like to get it running before getting rid of it.
Has anyone put any other head on this motor?
Does a VW 1.8 head fit? bolt pattern work?
Anyone near NY city/Brooklyn have a cheap head they want to get rid of???
Thanks.
Jay
I'm a 924 newbie...be kind.
PostPosted: Wed Nov 20, 2019 5:45 am    Post subject: Reply with quote
Probably just needs a headgasket
What 1.8? There is no 924 with a 1.8 engine, only the 924 head will fit.
PostPosted: Wed Nov 20, 2019 7:01 am    Post subject: Reply with quote
only a 924, 924 turbo, or AMC Grimlin 2.0 head will fit..
Maybe those old "audi van"s our engine supposedly comes from would fit?
They are all as rare as hens teeth though and a step backwards in performance.. I wouldn't say they are practical options at all..
Your probably best off posting a want to buy a head thread here and buying one from someone on the board..
BTW people here have been searching for 16 valve heads to fit for decades, and nothing..
PostPosted: Wed Nov 20, 2019 7:47 am    Post subject: Reply with quote
Search no more......modification in progress, but you will need to be a member to get tech area access
https://porsche924.co.uk/forum/viewtopic.php?f=122&t=33648
PostPosted: Wed Nov 20, 2019 7:58 am    Post subject: Re: Blown 924 2.0 head...anything else work on the 2.0? Reply with quote
Thanks.
Jay
Most engines will run longer without oil than without water.... So, no big surprise.
A new head gasket and maybe skim the head if it warped, you cant skim it much.
Juho
PostPosted: Wed Nov 20, 2019 1:26 pm    Post subject: Reply with quote
What is in that post? Got me interested but im not a member
PostPosted: Wed Nov 20, 2019 6:41 pm    Post subject: Reply with quote
Someone is modifying a Ford 16V head to fit the 924 block.
Juho
PostPosted: Thu Nov 21, 2019 3:29 am    Post subject: Reply with quote
What kind of modification is necessary? Is this something any one of us could do without costing too much.
PostPosted: Thu Nov 21, 2019 3:58 am    Post subject: Reply with quote
No.
Same cylinder spacing, basically everything else needs modifying.
Not really a worthwhile effort in my opinion, the stock heads can flow pretty decent, maybe not 200 hp NA, but if you want that power level add some boost.
Raize
PostPosted: Sat Nov 23, 2019 1:50 am    Post subject: Reply with quote
Audi 100 2.0 is the same head but uses carburetors so no injector holes.
PostPosted: Sat Nov 23, 2019 7:41 am    Post subject: Reply with quote
Mill head buy COmetic head gasket and ARP head studs. No longer trust stock bolts and new replacements probably Chinese junk IMO
Mike
'77 924
cricketdesigns.com
snakoil
PostPosted: Wed Nov 27, 2019 7:15 am    Post subject: Reply with quote
I'm an 8 hours drive away but I do have a 2.0 head that has been verified and aligned that I can sell if you need it.
1979 924 NA
JaySilver
PostPosted: Mon Dec 02, 2019 7:47 am    Post subject: Reply with quote
The shop said the head was junk. The exhaust port on the #2 cylinder had massive holes in it as well as material missing from the little space between the #1 and #2 cylinders...
Thanks for all the help. Sorry it took me two weeks to get back on here...
JaySilver
PostPosted: Mon Dec 02, 2019 7:49 am    Post subject: Reply with quote
