Fuel relay question
immerohnegott
PostPosted: Thu Nov 28, 2019 1:50 am    Post subject: Fuel relay question Reply with quote
Hey folks,
Just started my first project car - '80 924 N/A - and I've got (surprise) a cold start issue. Before testing for trouble with the CIS system / WUR / idle air valve / etc, I have a quick question on the fuel pump relay since I noticed something trying to start her up this morning. When cranking, the relay clicks but I can't hear the pump run. Thankfully, said pump is loud enough you can hear it from the driver's seat which aids my troubleshooting a bit.
It does run for a second or two after ignition is cut back off, and once the car eventually stumbles to life it seems to at least run the pump consistently. Is this normal behavior? I feel like the relay should engage the pump while the starter is being turned, no?
Basically: Turn key, relay clicks a couple times but no sound from pump, stop cranking and the pump runs a couple seconds. From what I've read here, the pump relay is activated by a tach signal from the coil. This works, tach bounces when cranking and the gauge works when car is running, although it's an aftermarket MSD coil.
With the pump being as loud as it is (no weird grinding noises, just louder than I would expect), I'm sure it's on the way out but I haven't flowtested just yet. The car does run and drive once it gets turned over and warmed up, at least.
immerohnegott
PostPosted: Thu Nov 28, 2019 12:16 pm    Post subject: Reply with quote
Nevermind, I'm deaf and / or an idiot. Dug into it a bit more after work and the relay seems to be working as intended with the pump spinning during ignition crank. Apologies, please disregard the previous post
PostPosted: Thu Nov 28, 2019 5:55 pm    Post subject: Reply with quote
make sure the pump is actually putting out fuel at the fuel dizzy.
Ruby-sh 924
immerohnegott
PostPosted: Fri Nov 29, 2019 12:23 am    Post subject: Reply with quote
Oh certainly. I need to make a jumper switch for the relay and flowtest it at the distributor inlet anyway - I just thought I had an electrical problem compounding things
