924 2.0 NA flywheel lock - help needed
Witty924
PostPosted: Thu Nov 07, 2019 6:29 am    Post subject: 924 2.0 NA flywheel lock - help needed Reply with quote
Hi all,
Need a little help on removing the infamous crank bolt. I need to track down a flywheel lock for my 924 2.0 NA. I can only find locks for the 924 s 2.5l or 944 and wondered if they happened to be the same size starter ring with teeth spacing as the 2.0l NA.
I have tried the home approach of locking in gear with brakes on but still too much play in the transmission/clutch so can’t crack the bolt off.
I don’t have access to air tools or impact gun so looking for the lock as my only option.
Thanks in advance
Witty
Witty924 - Porsche 924 2.0l NA 1984
Ozzie
PostPosted: Thu Nov 07, 2019 7:06 am    Post subject: Reply with quote
Having an auto NA I couldnt put in gear and undo mine either.
The work around (not recommended) for me was remove the coil HT line to dissy and using a long breaker bar.
Lock the breaker bar against the chassis and briefly crank the engine. this loosened the crank nut so I could remove the pully.
Its AUTO and its BLACK
Montego Black on black/red
Witty924
PostPosted: Thu Nov 07, 2019 11:06 pm    Post subject: Reply with quote
Thanks Ozzie,
Very creative
Did you have any issues with the bolt after that, rounded head etc?
Thanks
Witty
Ozzie
PostPosted: Fri Nov 08, 2019 6:34 am    Post subject: Reply with quote
no, all good after.
Removing HT lead from coil is a must, heard stories of engine starting when others have tried this.
I also used loctite when replacing
Witty924
PostPosted: Sat Nov 16, 2019 9:11 am    Post subject: Reply with quote
Thanks Ozzie
Appreciate the reply.
Will let you know how I get on
Svobodin
PostPosted: Sat Nov 16, 2019 8:48 pm    Post subject: Reply with quote
944 flywheel lock should work... the 944 has the same starter, I have swapped those between models, so I don't see why the flywheel lock wouldn't bolt up.
Witty924
PostPosted: Sun Nov 24, 2019 10:35 am    Post subject: Reply with quote
Thanks SVO
Couldn’t find any info on a 2.0l vs 2.5l and starter ring differences.
If you have used a lock on both types and it worked that’s good to know
