Juho
Posted: Tue Oct 22, 2019 4:32 am Post subject: |
While soldering lambda wires melted a little bit of the bucket seat fabric and now im pssed |
Juho
Posted: Wed Oct 23, 2019 1:31 am Post subject: |
Quick question, are these wires the correct way? |
Juho
Posted: Wed Oct 23, 2019 4:06 am Post subject: |
ive just realised i installed bearing caps wrong way..... i guess its time to do it again tomorrow |
Juho
Posted: Wed Oct 23, 2019 4:25 am Post subject: |
2,3,4 are wrong way right? I read the manual and thought the 459 was supposed to be readible from back of the head |
Juho
Posted: Wed Oct 23, 2019 5:11 am Post subject: |
The 459 is readible from back of the head but the stamps arent. |
safe
Posted: Wed Oct 23, 2019 5:26 am Post subject: |
Aren't they asymmetric? |
Juho
Posted: Wed Oct 23, 2019 5:33 am Post subject: |
Yes, 3 rounded corners and 1 sharp, mine are facing right direction when i look at other peoples caps from other posts, but haynes manual says that the stamp should be readible from back of the head |
safe
Posted: Wed Oct 23, 2019 5:47 am Post subject: |
Juho wrote: | Yes, 3 rounded corners and 1 sharp, mine are facing right direction when i look at other peoples caps from other posts, but haynes manual says that the stamp should be readible from back of the head |
Yes, but isn't the distance between the studs and cam different side to side so you cant put them on backwards? |
Juho
Posted: Wed Oct 23, 2019 6:19 am Post subject: |
safe wrote: | Juho wrote: | Yes, 3 rounded corners and 1 sharp, mine are facing right direction when i look at other peoples caps from other posts, but haynes manual says that the stamp should be readible from back of the head |
I dont know, shouldnt be mine be good when compared to these pictures
Posted: Wed Oct 23, 2019 7:54 am Post subject: |
Does the cam turn? Having the caps on the wrong way will bind it up. Valve spring tension on the lobes is the only thing that prevents it from easily turning when the caps are on correctly. There ought to be a few places where you can rotate the cam back and forth a bit. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Juho
Posted: Fri Oct 25, 2019 3:53 am Post subject: |
I've created a whole new vocabulary in my garage past these weeks....
Ive only got to put on the timing belt and get a bigger fuel line for the regulator to carbs because the expensive one i got atm doesent fit. Then i should be able to start it. and also tighten camshaft cover and intake manifold bolts <------ anyone have tips for doing them?? its so annoying
Juho
Posted: Fri Oct 25, 2019 3:54 am Post subject: |
oh yeah, guess whose hood isn't going to close |
safe
Posted: Sun Nov 03, 2019 1:40 am Post subject: |
How is it going?
Started up yet? |
Juho
Posted: Thu Nov 07, 2019 9:15 pm Post subject: |
so the backplate i ordered doesent fit sending it back and waiting for a new one |
safe
Posted: Thu Nov 07, 2019 9:51 pm Post subject: |
Just make one. Cardboard template, some aluminium sheet and an electric jigsaw. |
