924 CGT tranny
PostPosted: Tue Aug 27, 2019 2:36 am    Post subject: 924 CGT tranny Reply with quote
Was the 924 CGT equipped with LSD as standard feature?
This looks like a regular 1980 931 tranny to me:http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/1038213-924-carrera-gt-transaxle.html
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Tue Aug 27, 2019 3:09 am    Post subject: Reply with quote
I thought they were supposed to also have some sort of strengthened gearsets from shotpeening or cryo treatment and be setup for an oil cooler also..
Or maybe that was the GTS and higher trannies..
PostPosted: Wed Aug 28, 2019 4:46 am    Post subject: Reply with quote
CGT had ZF plate type LSD as stock with uprated gear set, synchros and crown wheel. No idea if outer casing is same as turbo or if numbers will aid telling you what’s inside is CGT. Turbo boxes with an LSD had a /12 after the gearbox serial number. Some history would be helpful as the plates in the LSD will wear over time and use and new plate pack may be needed.
PostPosted: Tue Oct 08, 2019 6:57 am    Post subject: Reply with quote
CGT did not come stock with LSD (mine didn't have it), but it was an option as with all snailshells, and indicated by /12 after the serial number. I can't see the link at Pelican (site appears to be down?), but the case must be number G31.50 in order to be a CGT box (from memory, ROW = G31.01, US = G31.02).
