mikseymono1
Joined: 08 Feb 2019 Posts: 10 Location: Brittany, France
Posted: Fri Feb 08, 2019 5:45 pm Post subject: Oil Pressure light - random flickering |
SO, oil pressure light on the instrument cluster (oil can picture) has been flickering over the last couple of weeks. Not a constant blink like an indicator, more like a random flicker….sometimes a hard red…sometimes a soft one…..like an electrical problem. Have not used car much in the last month…weather…maybe four 10 min journeys at best….yesterday, I changed the Oil (Castrol GTX Ultraclean 10w40) OEM oil filter and put on a brand new OEM Oil Pressure sender. Oil pressure on cold starts pegged at 5 then after 15 mins it goes to around 3.4 on idle…so not far off Clarks guide.
Took it for a spin today…upon start the oil pressure goes to 5 and sure enough the oil pressure light starts to flicker……after 3 mins…light goes away…drive for another 15 mins….light flickered once during this time and that was it.
So…a bit strange. I can’t seem to get it to come on with acceleration/braking etc..it has a mind of its own...I have checked wires from sender and ensured good contact to the sender to both the connections and have also checked back to under the manifold area. I have an oil level sender on the sump and the wires look ok…but unsure how to test that.
So, a bit strange and random. It really seems electrical rather than a mechanical fault…just can’t trace it. I guess in the grand scheme of things if the car is pulling well, with good oil pressure, no obvious leaks all is OK…just this flickering light is annoying...
Any pointers greatly appreciated.
Cheers,
M _________________ 9242 - 1988 |
ConradK
Posted: Thu May 23, 2019 2:28 am Post subject: |
I have the same issue. I was reading elsewhere that the oil light flickering is a symptom of a failing low oil level switch which are NLA. There apparently isn't an easy way to defeat it. I would assume you can pull the connector to the light but maybe that has an impact on something else? Maybe someone else here can comment. _________________ 88 924S |
Posted: Sat May 25, 2019 6:44 am Post subject: |
Could be the wire from the sensor to the light is shorting to ground. _________________ White 87 924S "Ghost"
mikseymono1
Posted: Sat May 25, 2019 4:18 pm Post subject: |
I have tried all those.
So I have come to the conclusion the the sensor in the oil sump is probably the culprit. I have bypassed the oil sensor relay and so far no flickering light and it's been fine for 3 months........might try to connect the relay back up just to see if the problem is still there.... _________________ 9242 - 1988 |
Posted: Sat May 25, 2019 11:01 pm Post subject: |
I was referring to the oil pressure sensor lead.
In the case of the level sensor, simply grounding its connection at the sump will take care of the issue. _________________ White 87 924S "Ghost"
mikseymono1
Posted: Sun May 26, 2019 2:31 am Post subject: |
I tried grounding that wire Paul...but still flickered. I ended up taking off the oil pressure relay and inserting a wire to bypass that...I had read someone had similar issues and this solved it by doing just this. I might put it all back together and test it again as it was the deepest winter when it developed this strange issue! _________________ 9242 - 1988 |
Posted: Sun May 26, 2019 8:37 am Post subject: |
Since it still is flickering with the level sensor lead grounded, the issue is not the level sensor. The sensor grounds the lead until the oil level gets too low when it opens the path to ground. _________________ White 87 924S "Ghost"
mikseymono1
Posted: Fri May 31, 2019 2:45 am Post subject: |
well...put it back together again.....flickered a bit on start up but has been fine all day! Been using it quite a bit today so all very strange. I do park on a slight hill with nose up if this may contribute....and the last time I had this issue I had changed the oil and filter...so a bit baffled.....oh well...on to the next challenge!
