931 Tech To do list
Goto page Previous  1, 2, 3, 4, 5  Next
MOTANUL
PostPosted: Tue Jan 29, 2019 9:31 pm    Post subject: Reply with quote
I cut the spark plug wire and vacuum hose to size. I whant to change ignition lead-ignition coil.
I have a much better one at home.
sold Porsche 924 NA 1979
Johann
PostPosted: Wed Jan 30, 2019 9:26 pm    Post subject: Reply with quote
Just a quick question on the spark plugs. Has anyone found a way of replacing them without taking apart the inlet tract?
CÚdric
PostPosted: Wed Jan 30, 2019 11:40 pm    Post subject: Reply with quote
I find the tool from the original tool set quite handy when it comes to swap them.
┤80 924 Turbo
Johann
PostPosted: Thu Jan 31, 2019 12:06 am    Post subject: Reply with quote
OK, and you can get to all of them without removing the Boost pipe? My car didn't come with the tool set Do you have a picture?
CÚdric
PostPosted: Thu Jan 31, 2019 12:10 am    Post subject: Reply with quote
Im sure it works with other tools aswell, it just worked better than what i had in my garage.
http://www.classicshop.porsche.com/pcos-usa/equipment/tool/tool-bag-for-porsche-porsche-924-924-s-944-9442-and-968-94472102705.html
https://www.ebay.com/itm/EXCELLENT-ORIGINAL-GENUINE-PORSCHE-924-944-968-KLEIN-21-SPARKPLUG-SOCKET-TOOLKIT-/372195136091
┤80 924 Turbo
MOTANUL
PostPosted: Thu Jan 31, 2019 2:44 am    Post subject: Reply with quote
Ref. to: the stabilizer bar bushing
I received a lot of: no longer available
The only ones that came are manufactured in 2009
I still need 6 more.
I had time to galvanize all the pieces. They were pretty rusty.
MOTANUL
PostPosted: Mon Feb 04, 2019 7:59 am    Post subject: Reply with quote
ref. to: TURBO central tube (Torque tube rebuild) manual transmission G31.01
Does anyone know the tube bearing spare part codes for 931?
Can I find bearings complete with plastic piece around?. Not only the bearing itself.
MOTANUL
PostPosted: Sun Feb 10, 2019 10:01 pm    Post subject: Reply with quote
After 3 weeks I "managed" to buy all the bushings from stabilizer bar. (8 bushings - Gummibuchse ).
Central ones: 477411313H stabiliser mounting 23 mm Porsche 924 Genuine Porsche
Lateral push rod 23 mm: Porsche 924 no longer available. I use Porsche 944 477411053J (perfect fit)
477411041B rubber mounting - Porsche 924 no longer available. I use Porsche 944 - 95134379501. It was necessary to cut off a part of them as they are not identical to those of 924.
MOTANUL
PostPosted: Tue Feb 12, 2019 7:16 am    Post subject: Reply with quote
1. There is any upgrade to Oil Separator 93110722101?
2. Can the gasoline metal tank be replaced with 944 plastic? It's a perfect fit or need major changes?
admin
PostPosted: Tue Feb 12, 2019 12:40 pm    Post subject: Reply with quote
MOTANUL,
Link removed. Another attempt to post such links will result in immediate ban.
Remember; This is a democracy, one man, one vote. I'm that man and this is my vote.
PostPosted: Tue Feb 12, 2019 6:23 pm    Post subject: Reply with quote
huh? what did he post?
red 924 and not red 924
924-76
PostPosted: Wed Feb 13, 2019 4:58 pm    Post subject: Reply with quote
Not that I know
It can be done, but it's not a direct bolt-on:http://www.924board.org/viewtopic.php?t=29582
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
MOTANUL
PostPosted: Fri Feb 15, 2019 11:22 pm    Post subject: Reply with quote
Ref. to: Oil Separator 93110722101
The air filter is damp with oil and I wanted to solve this problem.
Ref. to gasoline metal tank
The tank on the 924 NA was dry. The current tank (931) is dry and with a little surface rust. No drop of gasoline (fuel pump, pressure acumulator, lines, etc). But it smells like gasoline in the tank area. (on both cars)
It's too much metal work to mount the plastic tank (944).
What can I do not to have smell of gasoline in tank area?
PS: For the pressure plate bearings things go slowly(rusty, dirty parts, broken screws). Many are already solved, others are in progress.
PostPosted: Fri Feb 15, 2019 11:54 pm    Post subject: Reply with quote
Oil separator/Purolater has a few options, neither is ideal as these engines have too much oil vapour
1. leave Purolater connected to S1 turbo airbox intake, oil vapour pools in the box and wets out the air filter
2. install a S2 fuel/air meter unit. The Purolator connects under the unit bypassing the air filter and avoiding the wetting out
3. Use a generic oil separator and vent the crankcase to atmosphere. The issue is the oil vapour will splash around the engine bay. More boost, more vapour
MOTANUL
PostPosted: Sat Feb 16, 2019 6:59 am    Post subject: Reply with quote
This solution seems to be the best for me. Is it enough just to replace the under part and mount the hose there? Keeping the rest original? (upper kjetronic fuel distributor - The Purulator, etc).
Page 4 of 5
