Johann
Posted: Thu Aug 31, 2017 2:16 am Post subject: |
Not yet, but it is in the planning I am having a custom primary silencer delete pipe made up with a socket for an oxygen sensor. |
Posted: Fri Sep 01, 2017 3:44 am Post subject: |
Controlpressure cold is 2.0--2.8 (depending on S1/S2)
So I think you injectors are fine _________________ 937 trackday car
Johann
Johann
Posted: Wed Sep 13, 2017 6:23 pm Post subject: |
And now, after fixing many niggles, she idles like a champ. Hot and Cold
To get here I did the following:
- New Coil
- Fixed the engine wiring harness going to AAV and WUR
- Made the idle mixture a lot richer
- Cleaned the connection to the Idle stabilizer
- Ditched my CO meter and adjusted the A/F Ratio with my ears and nose.
http://www.youtube.com/watch?v=ua5snsA5Y3Y |
bear924
Joined: 26 Jul 2005 Posts: 95 Location: South West Queensland, Australia
Posted: Sun Oct 08, 2017 10:11 pm Post subject: |
I'm currently running my 924T rick due to a cold start issue as well. What I've discovered is that the oil canister between the turbo and block is causing a vacuum leak when cold.
I'm also getting really poor vacuum reading (ie.. not enough vacuum) which suggests a largish vacuum leak. =Your symptoms sound similar to mine, so I thought I'd mention my findings. |
