Joined: 08 Jun 2010 Posts: 1227 Location: Maysville, Colorado
Posted: Fri Apr 07, 2017 10:33 am Post subject: Rear caliper holder torque + Other |
I'm installing the rear caliper bracket/seal cover on my 5 lug conversion. What torque should the 4 10mm bolts be? What torque should the 12mm bolt that holds the trailing arm to TB carrier be? Haynes doesn't cover it. _________________ Mike
'67 MG Midget Dp
Posted: Sat Apr 08, 2017 9:43 am Post subject: |
Found the numbers in the Tech Specs sheet. _________________ Mike
'67 MG Midget Dp
