mikeycrum14
Joined: 19 Jan 2017 Posts: 110 Location: Juneau, Wisconsin
Posted: Tue Mar 28, 2017 4:27 am Post subject: Cabin Heater |
It wont turn off! ideas? _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap |
Joined: 29 Jul 2001 Posts: 8816 Location: Royal Oak, MI, USA
Posted: Wed Mar 29, 2017 4:15 am Post subject: |
Which won't turn off - the heat part, or the fan part? _________________ Vaughan Scott
mikeycrum14
Posted: Thu Mar 30, 2017 1:35 am Post subject: |
the fan part. the coolant switch works. its stiff and needs replaced but it works. _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
Harm
Posted: Fri Mar 31, 2017 4:59 am Post subject: Re: Cabin Heater |
mikeycrum14 wrote: | It wont turn off! ideas? |
This is standard from ~1980 up…
Key lock in on position activates blower. |
mikeycrum14
Posted: Tue Apr 11, 2017 1:25 am Post subject: |
so the fan is supposed to constantly run? _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
Harm
Posted: Tue Apr 11, 2017 3:05 am Post subject: |
mikeycrum14 wrote: | so the fan is supposed to constantly run? |
Yep. At a very low speed. It has something to do with cabin pressure and exhaust gases versus fahrfergnugen gegenuber Stuttgarter-wiedergutmachschnitzel bla-bla-blah
Cheers. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
mikeycrum14
Posted: Tue Apr 11, 2017 4:29 am Post subject: |
anyway to turn it off? _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
Harm
Posted: Tue Apr 11, 2017 5:46 am Post subject: Re: Cabin Heater |
Not that I'm aware of, other then pulling one of the fuses?
Normally the blower turning at low speed shouldn't be "upsetting".
Couldn't it be a Previous Owner hacked the electrical harness so it runs on a different speed?
Do you have any reference or a 924* nearby to compare its standard speed?
Why is it bothering you; Exhaust gases in the cabin will give you (at least) a headache
Cheerio
*earlier Toofah's don't have this upgrade and are known to have Cabin Fumes _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
mikeycrum14
Posted: Thu Apr 13, 2017 1:36 am Post subject: |
well, it blowing hot on high speed gets really warm in that cabin... and I might just unplug it for the summer... will go look at a reference if I can find one _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
Harm
Posted: Thu Apr 13, 2017 5:02 am Post subject: Re: Cabin Heater |
It sounds like you have a different problem then;
If you're unable to stop the coolant flow by flipping the lever,
try it by hand in the engine bay. See number 35 in the image?
#35 is what the cold—hot lever switches; opening or blocking the coolant flow (borrowed from the engines head).
Look under the hood, ~between firewall and underneath the WUR, and switch it by hand so it wil blok the coolant by-pass and you'll have un-heated air entering the cabin…
HTH _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
mikeycrum14
Posted: Wed Apr 19, 2017 12:12 am Post subject: |
yep I know what you are talking about. how hard is it to replace that valve? mine was pretty stiff _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
