pcelenta
Joined: 16 Feb 2007 Posts: 546 Location: long island,ny
Posted: Sat Nov 12, 2016 5:03 am Post subject: 931 cylinder head bolts |
| can anyone clarify....are they the same as the NA cylinder head bolts?? seeing conflicting info. is it worth it to update to studs? |
Posted: Sat Nov 12, 2016 5:40 am Post subject: |
The ARP kit is fairly inexpensive, and it is certainly convenient to unscrew the studs for head removal/installation. _________________ Toofah King Bad
Posted: Sat Nov 12, 2016 11:25 pm Post subject: |
The head bolts are the same. I believe the early NA studs have been deprecated. I am aware of only one available part number currently available.
That said, I highly recommend the ARP head studs, as they have an Allen key for easier installation and removal, as Rasta mentioned. They also provide better and more consistent clamping force, which is important on forced induction applications, particularly when increasing boost beyond OEM levels. Unlike the OEM bolts, they are reusable.
http://garage.ideola.com/prod-EngineRebuildKits.html#ARP _________________ erstwhile owner of just about every 924 variant ever made |
pcelenta
Posted: Sat Nov 12, 2016 11:30 pm Post subject: |
Thanks Dan! I have a bunch of stuff I will be ordering from you shortly. I am currently prepping #99s engine for rebuild. Body is coming along...still a way to go though.
Regards
Paul |
