Upper radiator hose source
Qik Nip
PostPosted: Wed May 11, 2016 9:24 am    Post subject: Upper radiator hose source Reply with quote
I'm in the late stages of the LSR car build and have sucessfully sourced all the cooling hoses except the upper radiator hose (the one with the bleeder valve) and the short molded S shaped thermostat to water pump hose. I could reuse the old ones, but I'd really not like to have to do so. Anyone have a line on either? Pelican, Paragon, Jegs, Summit, Rock Auto, ect are a non starter.
Rick
'79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11
PostPosted: Wed May 11, 2016 9:52 am    Post subject: Reply with quote
The S hose is NLA. I would strongly recommend finding something close that you can adapt, as that hose frequently develops pinhole leaks (in my experience), and I wouldn't want to risk a fresh build on an old hose. Unfortunately, I haven't yet had time to chase down a reliable / repeatable aftermarket option.
I wasn't aware that the bleeder hose was NLA, but I believe I may have an extra NOS unit somewhere in my parts bin. I'll do some digging on part numbers and see if I can get a new one.
agfisher
PostPosted: Sun Oct 02, 2016 12:13 pm    Post subject: Reply with quote
Hey Dan,
Any news on finding replacements for some of these coolant hoses? Is everything sort of "find what you can" now?
1977 924 N/A Martini Edition
Noahs944
PostPosted: Sun Oct 02, 2016 4:20 pm    Post subject: Reply with quote
I got one you can have for $2000 and take the rest of the car with it!
Duncan
PostPosted: Sun Oct 02, 2016 4:51 pm    Post subject: Reply with quote
all the hoses are available here, but very costly.
http://www.porscheshop.co.uk/acatalog/porsche_924_water_cooling.html
I think the hose with bleeder valve doubled in price over the last few years.
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
agfisher
PostPosted: Sat Oct 22, 2016 11:46 am    Post subject: Reply with quote
Found one at Autohaus for $30 I think just last week. When I get it I'll tell you if it is the right part.
PostPosted: Sat Oct 22, 2016 7:39 pm    Post subject: Reply with quote
That's because Porscheshop buy from Porsche. However they take your money first at a higher price than buying from Porsche direct. Then try to buy from Porsche, they find out it's no longer a available some days or weeks later then refund your money and in the meantime waste valuable spanner time
Power Tryp
PostPosted: Tue Oct 25, 2016 1:30 am    Post subject: Reply with quote
While not cheap Venair makes a substantial coolant hose kit for the NA cars. they delete the metal pipe that runs across but I assume you could just cut the hose to the right length after the curve and clamp it on.
http://www.andysautosport.com/radiator_hoses/porsche_924.html
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
brian19600
PostPosted: Tue Oct 25, 2016 1:50 am    Post subject: Reply with quote
Here's a couple of the hoses vary reasonable.
http://www.ebay.com/itm/NEW-Porsche-924-Base-1977-1982-O-E-M-ELAPLAST-Radiator-Hoses-Set-/351026622275?_trksid=p2141725.m3641.l6368
