Latest On My Conversion
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Nov 03, 2014 1:01 pm    Post subject: Reply with quote
Rattle cans?
v8carreragts
PostPosted: Mon Nov 03, 2014 10:55 pm    Post subject: Reply with quote
Rattle cans? No.
Two stage lacquer.
2015 AUDI Q7
2013 Chevy Cruze
v8carreragts
PostPosted: Mon Nov 10, 2014 3:37 am    Post subject: Reply with quote
Clearcoated. I just need to buff and polish it now.
2015 AUDI Q7
2013 Chevy Cruze
v8carreragts
PostPosted: Fri Jan 09, 2015 4:40 am    Post subject: Reply with quote
It's coming along! Mostly what is remaining to do is the interior and a few minor mechanical things.
2015 AUDI Q7
2013 Chevy Cruze
GeorgeV
PostPosted: Fri Jan 09, 2015 3:19 pm    Post subject: Reply with quote
Rattle cans?
Rasta, you're still a ST!
v8, the car looks great!
1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921
PostPosted: Sat Jan 10, 2015 2:43 am    Post subject: Reply with quote
The car does look great, but I was having a hard time imagining using a pro-style paint gun without a paint booth.
v8carreragts
PostPosted: Sun Jan 11, 2015 9:15 am    Post subject: Reply with quote
It isn't a problem because I used Lacquer. If I used If I used urethane or canalized enamel I would have needed to make a kind of booth with plastic sheet.
I'm almost ready to put the interior in now.
2015 AUDI Q7
2013 Chevy Cruze
v8carreragts
PostPosted: Tue Jun 16, 2015 4:01 am    Post subject: Reply with quote
Moved it on it's own power for the first time!
I didn't take it for a drive because I needed to shim up the hydraulic T/O bearing. The clutch was grabbing at the floor. Fixed that yesterday. Now I need to do a basic alignment so i can drive to the alignment shop, buy license plates and insurance.
Can't wait to go for a ride!
2015 AUDI Q7
2013 Chevy Cruze
PostPosted: Tue Jun 16, 2015 5:26 am    Post subject: Reply with quote
When you do, you should drive to Woodstock
Harm
PostPosted: Tue Jun 16, 2015 7:27 am    Post subject: Re: Latest On My Conversion Reply with quote
Neat!
PostPosted: Tue Jun 16, 2015 3:59 pm    Post subject: Reply with quote
Great looking car ! Must be one of the best looking reps out there.
Make sure to get us some videos if it.
v8carreragts
PostPosted: Thu Jun 25, 2015 5:54 am    Post subject: Reply with quote
Here are a couple of videos from yesterday. I only drove it up and down the block because I don't have plates or insurance yet. It feels good but still needs of tuning.
https://www.youtube.com/watch?v=2oCvxo6C_y4
https://www.youtube.com/watch?v=Kc2Kq5q5RF8
2015 AUDI Q7
2013 Chevy Cruze
v8carreragts
PostPosted: Sat Sep 17, 2016 10:44 am    Post subject: Reply with quote
Well, now that I have my garage set up and we are basically settled in here in Tucson, I finely got to do some work on the car. I couldn't get it to run well enough to trust driving anywhere so i called FAST tech support. They told me my cam had too much duration to work with a self learning system. (247/253 @ .050") So I called Crane and they ground me a custom cam. I got the car running Sunday and it runs great.
I also had some trouble with clutch engagement. After talking to Speedway Motors about the pressure plate I bought from them they said that this cover doesn't engage very smoothly and probably wouldn't be suitable for the street. So to get the car back on the road I just bought an OEM early HP Camaro pressure plate. It feels very smooth pushing the pedal down and letting it up. Then I started the engine and tried to drive it. With the engine running, doesn't matter if it it in neutral or in gear, the pedal is smooth going to the floor but coming up it binds like the pivot bushing is galled up. This makes it difficult to drive as it causes the clutch to chatter. I can't figure out why it only does this with the engine running.
I have a stock 944 clutch master cylinder and a McCleod hydraulic T/O bearing with a -3 braided line connecting them. The pedal assembly is all factory 944. It just seems crazy to do it only with the engine running.
Anybody have any ideas?
2015 AUDI Q7
2013 Chevy Cruze
PostPosted: Sat Sep 17, 2016 3:09 pm    Post subject: Reply with quote
Sounds almost like some wierd centrifugally triggered problem with the pressure plate assy.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
v8carreragts
PostPosted: Sun Sep 18, 2016 10:41 am    Post subject: Reply with quote
I had a suggestion from another forum and it turned out to be the problem. I needed to limit the pedal travel. It was pushing the pressure plate over center. I reduced the travel by about 2 1/2" with an adjustable stop I made up.
2015 AUDI Q7
2013 Chevy Cruze
Page 4 of 5
