Cheap-a$$ long rod + stroker + high CR pistons?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Sat Apr 20, 2013 5:31 am    Post subject: Reply with quote
Jason, is this for that block you got from me? If so, and you do this, I'd be interested in the rods and pistons from this block. dave.
PostPosted: Sat Apr 20, 2013 6:30 am    Post subject: Reply with quote
Indeed, the rods are probably good, but the top of those pistons look pretty beat up... I don't know what is acceptable and what isn't.
Otherwise I always have the engine that is in the car that could be broken down after the build.
PostPosted: Wed Apr 24, 2013 5:03 am    Post subject: Reply with quote
I just checked out my local machine shop and they are very reasonable to offset grind the crank.
I believe I've got the correct (longer) rods picked out and am trying to find a piston that gives me somewhere in the 8.6:1 to 9.1:1 CR.
PostPosted: Tue Jul 09, 2013 11:10 pm    Post subject: Reply with quote
Dan, whose ignition controller are you going to use for the EDIS ignition?
Mike
'67 MG Midget Dp
PostPosted: Tue Jul 09, 2013 11:42 pm    Post subject: Reply with quote
Since this motor will never be EFI'd (due to the carbs), I am planning to use MegaJolt to debug the sensor mount, sensor position, EDIS tuning, and spark map tuning.
PostPosted: Sat Apr 12, 2014 12:43 am    Post subject: Reply with quote
bump. which off the shelf parts get me 88 mm pistons, 150mm rods, 931
GeorgeV
PostPosted: Thu Apr 17, 2014 8:49 pm    Post subject: Reply with quote
Are you doing another rebuild flosho? I thought you had retired from 931ing?
1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921
PostPosted: Tue Apr 29, 2014 5:43 am    Post subject: Reply with quote
My love of the 931 is on life support and just barely hanging on.
PostPosted: Tue May 31, 2016 11:12 am    Post subject: Reply with quote
In situ.
procyon
PostPosted: Wed Jun 01, 2016 1:39 am    Post subject: Reply with quote
Looks really good. I don't see a crank position sensor. Is it not fitted yet?
1981 924 N/A (Now the parts car)
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2021 Maxda CX-30
PostPosted: Wed Jun 01, 2016 3:49 am    Post subject: Reply with quote
No, haven't had opportunity to mock up the bracket yet. I have the sensor, I have the trigger wheel and spacers fitted, just haven't done the bracket and pickup yet. So as not to introduce too many variables at once, I'm going to get the carb setup running reliably using the stock (conservative) ignition setup, and then swap in the programmable stuff later.
a239947
PostPosted: Thu Jun 02, 2016 1:35 pm    Post subject: Reply with quote
I'd love to know the part numbers of the pistons and rods used in this build. It would make it so much easier to find a local who might stock the parts. If not could you let us know the make and model of the cars these were for.
Figuring this stuff out is not that easy over this side of the world!
i hate to think what it was like in the non internet days!
Noahs944
PostPosted: Fri Jun 03, 2016 1:05 am    Post subject: Reply with quote
My god, Dan... this engine looks so tight from any angle. Well done!
XLR8
PostPosted: Sun Sep 13, 2020 12:00 pm    Post subject: Reply with quote
Hey Dan, did this work of art get rolling?
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
PostPosted: Mon Sep 14, 2020 10:45 pm    Post subject: Reply with quote
No. Wanna buy it?
Page 9 of 10
