nightrunner68667
Joined: 22 Apr 2016 Posts: 11 Location: Jackson, TN 38305
Posted: Mon May 09, 2016 8:12 am Post subject: clutch master cylinder |
needing to remove clutch master cylinder to rebuild, clutch is on the floor and car has been sitting up for a long time.....so.....the question is what all has to be removed to get to it? looks like removing the brake booster would make it a lot easier???? [/img] _________________ Always wanting to learn. |
Posted: Mon May 09, 2016 8:34 am Post subject: |
I use a 1/4" 13mm swivel socket. Easy peasy. Of course, clevis must be disconnected inside the car, and it is also a great time for hydraulic flush. Pull up the carpet and scrub your floorboard if master has leaked!
FWIW, I usually recommend master, slave & hose be replaced as a package. _________________ Toofah King Bad
kevingross
Joined: 15 Apr 2015 Posts: 35 Location: Stow, MA, USA
Posted: Mon Aug 15, 2016 9:27 am Post subject: |
I agree with Rasta. When he says "hose," I'd assume he means to include both the master-to-slave line as well as the pretty blue hose from the reservoir to the master. Good luck! _________________ Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com |
