Damage cilnderhead 924 turbo
Pascal924
PostPosted: Mon Dec 28, 2015 1:08 am    Post subject: Damage cilnderhead 924 turbo Reply with quote
Hello,
I have a badly damaged cilnderhead.
I need to shave around 0.65 mm, but is already at his minimum wear limit.
Is this possible?
Will valves hit the pistons?
What wil be THE cr? It is a 1979 931. I expert +0.5??
Thanks
PostPosted: Mon Dec 28, 2015 2:15 am    Post subject: Reply with quote
It is possible, particularly with the use of Cometic Multi-Layer Steel gaskets, you can make up the difference.
Standard gasket thickness was .049";
.045" + .065" = .110";
So you could use a .098" ($136) thickness gasket or a .120" ($224) thickness gasket to be pretty close to OEM spec without too much concern regarding interference or increase in compression ratio.
http://garage.ideola.com/prod-EngineRebuildKits.html#Cometic
You may still require a Vernier pulley (adjustable cam sprocket) in order to get the timing dialed in correctly, especially if you opt for the .098" gasket, because the head + gasket combination will still be outside of the wear limit.
Pascal924
PostPosted: Mon Dec 28, 2015 3:25 am    Post subject: Reply with quote
Thanks,
I think you calculate in inches, i calculate in mm...
I Will made a conversion.
Greetings
PostPosted: Mon Dec 28, 2015 4:45 am    Post subject: Reply with quote
Pascal924 wrote:
Thanks,
Greetings
Oops You are correct.
.65mm = .026"
So .026" + .045" = .071"
So you could select .070" or .075" MLS gasket.
Pascal924
PostPosted: Mon Dec 28, 2015 6:36 am    Post subject: Reply with quote
Thanks,
I Will shave the head and than see what i need.
Do they deliver to europ? Netherlands?
PostPosted: Mon Dec 28, 2015 8:22 am    Post subject: Reply with quote
Pascal924 wrote:
Thanks,
I ship to Europe, yes.
PostPosted: Mon Dec 28, 2015 6:05 pm    Post subject: Reply with quote
Nice one Dan...another Toofah saved!
Pascal924
PostPosted: Mon Jan 11, 2016 3:30 am    Post subject: Reply with quote
I went to an revision company, and they day that it was to bad.
The head needs to be welded and than shaved.
It was already 0.5mm under the min wear limit, and i need to shave at least an other 0.6mm.
This is too much. You could see already in the sparkplug hole that the head was shaved.
It will be relative costly....
PostPosted: Mon Jan 11, 2016 4:03 am    Post subject: Reply with quote
Sorry to hear the bad news
One of our forum members, Kenodog, has several used heads available for sale, send him a PM. It would probably be cheaper to have one shipped to you unless you can find one locally.
Pascal924
PostPosted: Tue Jan 12, 2016 6:58 am    Post subject: Reply with quote
Well, i can find a good head...and it is just to build a spare engine.
I Will keep the head, Some day, it Will be worth to repair it.
The crankcase and block is fine.
Have 4 good pistons, so with a new set of rings the engine is worth to rebuild.
It is difficult to find good parts.
I also have a turbo...with a cracked exhausthaus....hopefuly i can find a good one.
I aso have a k26 8.10 gts turbo, but i think it is to big for a standaard engine.?
PostPosted: Tue Jan 12, 2016 7:04 am    Post subject: Reply with quote
Interested in trading for a cylinder head?
PostPosted: Wed Jan 13, 2016 2:13 am    Post subject: Reply with quote
Correct, it is. It would work on my modified engine perfectly. I'll trade a cylinder head and it'll be cheaper to post than the US
WEASEL149
PostPosted: Thu Jan 14, 2016 6:51 am    Post subject: Reply with quote
That would be a good trade
1979 UK 932
PostPosted: Thu Jan 14, 2016 8:15 am    Post subject: Reply with quote
Is it this one??
K26-2670GA/8.10
5326-988-7008
If so would't this be worth much more than just a bigger turbo, for collector value, or to restore an original GTS?
It being a real GTS turbocharger and all, if it is, I don't think I would just run it on some modded 931..
Any way you could post pics of this thing and the tag numbers for my curiosity?
WEASEL149
PostPosted: Thu Jan 14, 2016 8:22 am    Post subject: Reply with quote
Fasteddie313 wrote:
Is it this one??
K26-2670GA/8.10
5326-988-7008
Carrera RSR's wheels ain't just "some modded 931"... it's THE modded 931
For THE, read definitive.
1979 UK 932
