9xx
Joined: 18 Jun 2006 Posts: 627 Location: Jarvenpaa, Finland
Posted: Sat Mar 07, 2015 5:35 am Post subject: |
morghen wrote: | ...and speed climbs uncomfortably. |
Come on, we all know how slow 924s are. You're propably just having the toofah hallucination _________________ Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944 |
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Sat Mar 07, 2015 5:57 am Post subject: |
9xx wrote: | Come on, we all know how slow 924s are. |
_________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Sat Mar 07, 2015 6:23 am Post subject: |
Only the Americans know
Good luck with that turbo, post some videos when it's running on the car. _________________ https://www.the924.com |
Shurick
Posted: Sat Mar 07, 2015 7:08 am Post subject: |
morghen wrote: | Only the Americans know
Good luck with that turbo, post some videos when it's running on the car. |
I hope I'll start my season in april, it depends on weather. _________________ WBR, Shurick
'86 924S -- R.I.P.
Shurick
Posted: Tue Mar 10, 2015 4:42 am Post subject: |
Not shure it is a performance upgrade, but it's definitely a part of my Frankenporsche.
Created a door card from two pieces of crap:
'86 924S -- R.I.P.
Shurick
Posted: Thu Jun 25, 2015 7:14 am Post subject: |
K26-6030-6.10 hybrid built:
'86 924S -- R.I.P.
Posted: Thu Jun 25, 2015 11:27 pm Post subject: |
Nice... _________________ 80 Turbo - Slightly Modified |
Shurick
Posted: Fri Jun 26, 2015 3:20 am Post subject: |
It looks to me that compressor housing sits too close to the body. Or the engine mount is shot. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Fri Jun 26, 2015 4:42 am Post subject: |
Engine mount is surely shot.
Mine has much more space...and i guess its exactly the same size. _________________ https://www.the924.com |
Shurick
Posted: Fri Jun 26, 2015 5:03 am Post subject: |
morghen wrote: | Engine mount is surely shot.
Mine has much more space...and i guess its exactly the same size. |
Ok, looks like it's time for engine mount spring winding.=) _________________ WBR, Shurick
'86 924S -- R.I.P.
Shurick
Posted: Sat Aug 08, 2015 8:51 am Post subject: |
Occasionally tested 1.4 bar of boost on a new turbo. It's so scaring fast that you don't have time to analyse your feelings. Going in third, step on throttle, 50-150 sprint and than rev limit comes - just it. You even don't have time to feel any fear. That fast.
Unfortunately (or fortunately?) 48 lb injectors are too small to feed the engine at that kind of boost levels: it learns up to 0.84 lambda @ ~95% duty cycle (while no pinging), so gone back to 1.2 bar boost .
Sadly I hadn't a camera in the car. 1.2 is also impressive and very fast but nothing special. (((( _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Sun Aug 09, 2015 1:21 am Post subject: |
cool, get bigger injectors ! _________________ https://www.the924.com |
Posted: Sun Aug 09, 2015 1:34 am Post subject: |
That is sick!! great work
At 1.4 Bar/20psi you have to be getting around 300 crank hp you think? Maybe a bit more? _________________ 80 Turbo - Slightly Modified |
