Diesel Guest
Posted: Tue Oct 29, 2002 6:52 am Post subject: |
Vince Ponz Guest
Posted: Tue Oct 29, 2002 7:13 am Post subject: |
For those of you who want to shorten the distance from the bumper end to the body of the car you have remove the bumper then the shocks.
Cut the back off the shock with a chop saw or hack saw. The latter will take longer.
The shock is filled with oil so get something to catch the oil.
After you cut off the back you will see that the guts of the shock comes out. So remove the metal etc. On the front remove the metal and rubber bits on the front of the bumper.
Now gently push in the shock front through the base until you measure about 3.25 to 3.5 inches from the tip of the shock to the base. Weld at the base.
Replace the shock on the body and put on the bumper.
Looks nice right.
[ This Message was edited by: Vince Ponz on 2002-10-29 08:15 ] |
redcar924 Guest
Posted: Tue Oct 29, 2002 9:37 am Post subject: |
I was thinking about doing this mod the other day, but I wasnt sure. Lets say, God forbid, you collide with something, what kind of damage could be expected?
Have you got any pictures of the car after the bumper was put back on?
Lizard Guest
Posted: Tue Oct 29, 2002 10:23 am Post subject: |
it increases the chance of bending the frame but these are only really good at low speeds under 60km/h I believe not sure though.
it is looks for safety
924_fan Guest
Posted: Tue Oct 29, 2002 2:39 pm Post subject: |
What frame?
Vince Ponz Guest
Posted: Tue Oct 29, 2002 10:41 pm Post subject: |
At about 5mph the shock will collapse. After that you are on your own.
Try not to have accidents.
If the hit is a strong one you will have to repair a lot of parts with or without the change in the shock.
Then again if it is not for you don't do it. I park all my cars far away from other cars in parking lots and so far so good. My rubber on my 931 Euro is still perfect after 2 years because I park away from others. This is in NY.
I will send you a picture. |
Lizard Guest
Posted: Wed Oct 30, 2002 3:40 am Post subject: |
yes you can bent or twis the frame/unibody on these cars. and if you park away from other cars great or if your like me and hate exercise park close I have never been hit, and if I saw someone hit me I would shoot him
tmb-racing Guest
Posted: Wed Oct 30, 2002 4:40 am Post subject: |
| Just food for thought-On my road race car I was rear ended at about 50mph on a waived off start by a toyota corolla-It was a real hard hit and looking back the corolla had pretty significant damage around the headlight area of his car-I just knew my poor 924 was tweaked bad in the back. After the race it turns outI had a 6inch white paint rub I just buffed out. I am unable to get to min weight but feel the trade off is worth it from a safety and bodywork standpoint. Remember this IS a Porsche engineered car. |
Joined: 29 Jul 2001 Posts: 9076 Location: Royal Oak, MI, USA
Posted: Wed Oct 30, 2002 4:51 am Post subject: |
Are you racing ITA, or what is your min weight? I'm down to 2620 w/ driver, still have more weight to lose.
How about windage/scraper trays? I'm trying to find one - do you know of anyone who's made one?
Posted: Sat Dec 07, 2002 3:53 pm Post subject: |
This is cool Im gonna do it and remove the rubber too. _________________ 1979 porsche 924 Na
Last edited by Joes924Racer on Thu Apr 24, 2003 10:35 am; edited 1 time in total |
Vince Ponz
Posted: Sun Dec 08, 2002 12:11 am Post subject: |
The picture in the previous posting is what the front of my car will look like when finished. I already cut the shocks and on the bumper filled in the holes where the large rubbers were. Looks just like the picture except with a 944 nose.
One problem with the above set up. The turn signals alone leave a space that has to be filled for a perfect look. The large rubber fills the space with an extension that fits between the bumper and the turn signal.
I will photo the car and send in the pics. It will be in primer but I guess we cannot be choosey. Rear flares were cleaned up and smoothed and just bolted to the body. Seams filled. The car will look goofy because of all the primer in spots I worked on. |
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Sun Dec 08, 2002 3:43 am Post subject: |
I personally don't like it. I like the stock "rat nose" look of the 924. it is nice. _________________ werd B. |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Sun Dec 08, 2002 4:21 am Post subject: |
| Porschephile wrote: | | I personally don't like it. I like the stock "rat nose" look of the 924. it is nice. |
I also like the nose (and having the rubber to protect it) but I also like the pushed in look of the back.
The problem I have with the mod is the damage that could be caused without the shocks. Thus, I'm still debating it. _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
Porschephile
Posted: Sun Dec 08, 2002 8:29 am Post subject: |
What are the benefits of doing this upgrade aside from cosmetice reasons? I was once told it was to move the center of gravity back a little more, but that doesn't make much sense to me, how a little part such as a fender can cause so much weight difference. _________________ werd B. |
AFBCamaro
Posted: Sun Dec 08, 2002 3:11 pm Post subject: |
It wont do squat for center of gravity, measurable only in formula. It is mostly only cosmetic. I for one have already taken the bumper of and i am heading for the cutter in a bit.
I was thinking... wait I cant say yet till im done.
Thanks Vince for your help _________________ 1982 Porsche 924 in mild restoration process.
1991 Chevy Camaro RS "Freigh Train" |
