Email: ponzv@aol.com
Date: 01 Jul 2001
Time: 10:01:29This is the first thing everyone should replace on hard starting. It is a simple job to do and should take about 5 mim. It is at the exit of the in tank fuel pump. Purpose of it is to stop the fuel from running back into the tank. When I replaced mine it was just a fitting with a hole in it. Someone replaced or cut out the valve. should not cost much. I would then check the accummulators, fuel filter and the engine grounds.
Vince
