Posted: Tue Nov 18, 2014 2:39 pm Post subject: |
Cut them behind the radiator mount, then make longitudinal cuts (think banana peel). Crunch cut ends together to make box section smaller, and tap on your new piece. When it's lined up, weld. _________________ Toofah King Bad
Posted: Tue Nov 18, 2014 10:10 pm Post subject: |
BTRacing wrote: | So you guys are suggesting cutting of whole frame rails? |
No. Unpick the front end from the front of the chassis rails. I didn't cut the rails themselves on my 931. It went back on as if totally original. Photos in my threads linked in my signature. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Wed Nov 19, 2014 12:48 am Post subject: |
I like the license plate, DDR, how appropriate~! _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Nov 19, 2014 1:00 am Post subject: |
Grenadiers wrote: | I like the license plate, DDR, how appropriate~! |
though DDR did have a severe lack of 924s...
Will be interesting to follow this build, keep it up ! _________________ 1980 924 Turbo
BTRacing
Joined: 31 May 2014 Posts: 434 Location: Nortbrook,IL
Posted: Wed Nov 19, 2014 12:32 pm Post subject: |
Here is few pictures from today.I started taking front end apart.Removed headlights assembly,fenders,lower valance and some AC components.
I am trying to save as much weight as possible.
I repaired passenger side floor and welded in new/old seat brackets.
Not much but some progress.
_________________ www.btr-chicago.com
1977 924 Martini
1993 Mercedes 190E Sportline LE, one of 700 made
2020 Ford F350 Tremor daily driver/tow pig
1974 Moto Guzzi Cafe Racer
2002 Formula Fastech 382 |
BTRacing
Posted: Wed Nov 19, 2014 12:34 pm Post subject: |
Here is a picture of my headlight kit and some of the customers cars that I am working on right now.
1977 924 Martini
Posted: Wed Nov 19, 2014 7:31 pm Post subject: |
You cut too much off each end of the 951 front end!! You should have joined on the inner wings where there is a factory seam.
951 panel in silver, stock panel is white
silver 951 front end grafted onto uncut & white chassis rails
full factory look using 951 front, rad and IC mountings plus super rare factory 931 bolt on badge panel
BTRacing
Posted: Thu Nov 20, 2014 5:46 am Post subject: |
I bought it like that
I am working on it right now,will post some pictures tonight _________________ www.btr-chicago.com
1977 924 Martini
BTRacing
Posted: Thu Nov 20, 2014 2:25 pm Post subject: |
So here is todays progress on the car.
Removed badge panel,cut out front end parts and reinstalled 951 pieces and fitted intercooler.Pretty happy with the way it came out.
[URL=http://s1090.photobucket.com/user/btracing/media/2014-11-1917
1977 924 Martini
BTRacing
Posted: Thu Nov 20, 2014 2:27 pm Post subject: |
1977 924 Martini
Posted: Thu Nov 20, 2014 7:27 pm Post subject: |
Very good _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Joined: 10 Dec 2006 Posts: 947 Location: Noosa Heads QLD Australia
Posted: Fri Nov 21, 2014 12:37 am Post subject: |
Like your work...BT! _________________ 80/81 932/8 ROW |
BTRacing
Posted: Fri Dec 12, 2014 12:41 pm Post subject: |
I have new to me late offset front spindles and hubs from 944 Turbo.It will be nice upgrade including Turbo brakes.
1977 924 Martini
Posted: Fri Dec 12, 2014 4:53 pm Post subject: |
What struts will you run? What front arms will you run?
Late spindles means late struts, late struts mean late front arms unless you modify something. _________________ https://www.the924.com |
Posted: Fri Dec 12, 2014 6:42 pm Post subject: |
What wheels are you going to run on that car? |
