coldwarvet
Joined: 13 Jun 2014 Posts: 51 Location: near sandy oregon
Posted: Sat Aug 09, 2014 9:27 am Post subject: injector sleeves for 931 |
...anyone sourced injector sleeves for the 931...S1?...not as part of some kit!... |
Posted: Sat Aug 09, 2014 3:44 pm Post subject: |
Aren't they same as the 924 NA and other Bosch CIS cars of the time with the same size threaded ports? Audi's used the 22mm size as did some Mercedes. Unless someone here has a better solution, that might help with the search.
Good luck! _________________ Stefan
coldwarvet
Posted: Thu Aug 14, 2014 2:15 pm Post subject: 931 injector sleeves |
...924 na and AUDI with the threaded injector ports use a plastic adapter, as the na engine simply uses vacuum to retain the injector...the turbocharged engine uses a threaded adapter which also has threads on the inside ( to match the threaded injector) so the injector doesn't get blown out of the port under boost...the 931 adapter also has an extended hex top so that it may be tightened with a wrench...
...anyone sourced these?... |
Posted: Fri Aug 15, 2014 1:31 am Post subject: |
Per PET, part number is 93111022601.
Pelican shows stock, I think I got four from Sunset Porsche. _________________ Toofah King Bad
Posted: Fri Aug 15, 2014 1:35 am Post subject: |
I stand corrected. Learn something new everyday.
Time to hit up the PET and see if you can acquire said inserts from Sunset Porsche (they usually have one of the better prices for OEM parts) or from one of the various online Porsche Parts specialists. _________________ Stefan
techfx
Joined: 11 Feb 2014 Posts: 25 Location: Pittsburgh, PA
Posted: Sun Nov 09, 2014 12:16 pm Post subject: |
Did you have any luck finding these? I got the last 2 from ECS earlier this year, but still have to find a few more. _________________ 81' 924 Turbo, 02 Golf TDi, 88 Scirocco 16v (RIP)... and the Subaru. |
