SlayerSST
Posted: Wed Jan 04, 2012 8:37 am Post subject: |
macBdog
Posted: Thu Jan 05, 2012 12:52 pm Post subject: |
OMG. Dude. Put the chisel down. Actually just step away from the car all together.
I can't even begin... _________________ 1979 931 with a 350 chev
1973 911E with EFI
| p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
Posted: Thu Jan 05, 2012 3:01 pm Post subject: |
Wow, that had to be fueled by beer.
You know it isn't that hard to reach that joint. Quite a bit less effort than chiseling a bunch of steel, I'd think. _________________ Stefan
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Jan 07, 2012 6:20 am Post subject: |
OH-EM-Gee!!! Fueled by stupid compounded by beer... That is so not right. At least use a cutoff wheel then weld the piece back in.  _________________ '80 924 Turbo - SOLD!
Porscheless  |
Posted: Sat Jan 07, 2012 7:12 am Post subject: |
Horsepucky, just pull the trans. Takes very little time on a snail, and the CVs are probably in need of a service anyway.
Poor car.
mudkip
Posted: Thu Jun 19, 2014 8:59 am Post subject: 1st gear poping out |
| hello I was having some issures with the shifting on my 924 turbo 1980 Porsche the shifting seems lose and it pops out of 1st gear im wondering if its a shift linkage issue maybe a bushing is warn b ut all the other gears go just fine so im wondering if its a issues in the trans mission or how I should go about fixing it |
Posted: Thu Jun 19, 2014 10:25 am Post subject: Re: 1st gear poping out |
| mudkip wrote: | | hello I was having some issures with the shifting on my 924 turbo 1980 Porsche the shifting seems lose and it pops out of 1st gear im wondering if its a shift linkage issue maybe a bushing is warn b ut all the other gears go just fine so im wondering if its a issues in the trans mission or how I should go about fixing it |
Hyou read the rest of the thread? The loose shoft lever requires replacing the shift coupler bushings in the rear and sometimes the rod end bushing at the top of the torque tube. Then flush the transaxle oil so you can refill with Redline transmission fluid and see where that gets you.
That said, I suspect you've got internal damage leading to the transaxle popping out of gear so youll need to pull the transaxle to refresh it internally. Ideola's Garage seems to be the only one carrying a refresh kit for your transaxle and it isn't too bad for expense. Plan on refreshing the CV joints and boots while you've got it out for service. _________________ Stefan
jason c
Posted: Thu Jun 19, 2014 10:51 am Post subject: Re: 1st gear poping out |
| fiat22turbo wrote: | | mudkip wrote: | | hello I was having some issures with the shifting on my 924 turbo 1980 Porsche the shifting seems lose and it pops out of 1st gear im wondering if its a shift linkage issue maybe a bushing is warn b ut all the other gears go just fine so im wondering if its a issues in the trans mission or how I should go about fixing it |
That said, I suspect you've got internal damage leading to the transaxle popping out of gear so youll need to pull the transaxle to refresh it internally. Ideola's Garage seems to be the only one carrying a refresh kit for your transaxle and it isn't too bad for expense. Plan on refreshing the CV joints and boots while you've got it out for service. |
That just about covers it. Popping out of gear is likely caused by worn bearings and/or broken springs & worn detents. |
A1ain
Joined: 07 Apr 2017 Posts: 6 Location: Auckland, New Zealand
Posted: Tue Aug 22, 2017 8:17 pm Post subject: 016Z transaxle removal |
Hi everyone, just removing the Snailshell transaxle from my 79 924. Has anyone got tips on:
-accessing the top two bolts holding the transaxle to the torque tube?
-accessing the bolt holding the shift coupler to the transaxle?
Also, if I wanted to remove the torque tube, are there pinch bolts I have to access where it attaches to the bell housing?
Thanks, Alain _________________ '79 924 NA |
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Thu Aug 24, 2017 12:38 pm Post subject: |
Top two bolts are crazy hard unless you have lots of angle drives, long extensions and short sockets. Easiest solution is to cut a panel in the body between the two rear seats. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
A1ain
Posted: Thu Aug 24, 2017 6:53 pm Post subject: |
Thanks for the reply. Sounds pretty drastic, I will definitely avoid cutting holes into the body. I'll have a go with the tools, do happen to have quite a few attachments. If it's not possible, does this mean removing the transaxle with the torque tube all together? Thanks. _________________ '79 924 NA |
Posted: Thu Aug 24, 2017 6:59 pm Post subject: |
Its no big deal, take the half shafts off first, then remove the exhaust and gearbox mounts.
Let the gearbox sit on the torsion bar housing and that will make it much easier to reach those bolts.
Before reaching those bolts get the linkage undone as you will get even more space to work.
In the end use two extensions with a rotateable joint in the midle and the correct bit at the end. Use a big lever as those screws are tight but its actually not difficult to get them out.
Support your gearbox all this time and dont forget about the power shaft coupling, it has two bolts as well. _________________ Supercharger and EFI kits
https://www.the924.com |
A1ain
Posted: Fri Aug 25, 2017 12:27 pm Post subject: |
Cool, thanks for the tips! I'll give it a go this weekend _________________ '79 924 NA |
