Posted: Thu Feb 06, 2014 11:06 am Post subject: braking solution for engine swaps? |
I saw this on Gears and he used it on a truck that needed more room under the hood. Has any considered this idea?
http://powerbrakeservice.net/bosch-hydromax.html |
Posted: Thu Feb 06, 2014 11:42 am Post subject: |
The v8 guys use the BMW Hydroboost solution. Much cheaper as you pick it up at the local salvage yard.
Or they swap the master cylinder over a manual brake solution using dual master cylinders with an adjustable bias bar. _________________ Stefan
Posted: Thu Feb 06, 2014 12:03 pm Post subject: |
| Yeah I knew about that. But just some thinking. |
Posted: Fri Feb 07, 2014 5:13 am Post subject: |
| I was also thinking for swaps other than v8. Like steve's 1.8 swap he had to use a different intake because the passat one hit the master cylinder. |
AppleBit
Joined: 16 Nov 2002 Posts: 1516 Location: Minneapolis, MN
