brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Sun Sep 29, 2013 9:10 pm Post subject: Curious Question: How to make a rev monster? |
This is more of a ponder than serious question, but what would need to be done to make an early car ('77) with '81 head on it be able to safely rev to something like 7500-8000 rpm and still be streetable? Would it even be possible? _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Posted: Mon Sep 30, 2013 12:56 am Post subject: |
It would need to be precisely balanced, obviously, and need a serious upgrade to the fuel delivery system! Lightening the valve train would probably be beneficial as well. _________________ Toofah King Bad
Posted: Mon Sep 30, 2013 1:25 am Post subject: |
Lightened or aluminum flywheel.
Lighter rods and pistons. Possibly even a lightened and/or knife edged crankshaft.
Ported head and higher compression to flow enough air at that RPM
Higher lift cam possibly
Lightweight lifters, which may or may not require stronger valve springs.
Better intake and exhaust (header, side draft carbs or a larger plenum/throttle body)
The lifters are a problem on the street since they require dissasembly of the camshaft to adjust for wear.
Since you'll be pushing the engine pretty hard, a reversed cooling system isn't a bad idea either. _________________ Stefan
Joined: 28 Feb 2008 Posts: 1362 Location: Washington DC area
Posted: Mon Sep 30, 2013 2:23 am Post subject: |
The stock cam runs out of snuff at around 6000 RPM. It will rev higher but why bother. You will need a better cam profile to have fun in the upper ranges. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Posted: Sat Nov 23, 2013 1:48 pm Post subject: |
This combination ought to get you close: _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Joined: 18 Jun 2009 Posts: 671 Location: Sydney, Australia
Posted: Tue Nov 26, 2013 7:58 am Post subject: |
How would the standard bottom end go above 7000rpm? _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Tue Nov 26, 2013 8:27 am Post subject: |
I don't think the bottom end is the problem, although lighter rods, pistons, and flywheel would help with freer revving, obviously. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Posted: Wed Nov 27, 2013 8:01 am Post subject: |
So what compression ratio is recommended with the stage 3 cam? _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
