DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Sat Sep 15, 2012 3:16 am Post subject: |
"That’s it, will give it a try over the week-end, but it also slow things down. "
Its very important to use Australian QUALITY beer... got to be cold and full strength...
Good idea BUT good canadian beer will handle that job no problem!!!! We do know how to make it over here!!! _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Mon Sep 24, 2012 1:39 am Post subject: |
Pull the engine out, what a PITA compare to the N/A engine.
I believe it time for a new clutch.
And everybody knows that electric tape is the best thing against vacuum leak, right!
_________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Posted: Sun Mar 24, 2013 8:33 am Post subject: |
I finally got some time to work on my 931 project.
I pulled the head off today, planning on cleaning the carbon and reassemble within the next mount.
This will include:
APR head stud
3 layer MLS head gasket
NOS turbo S1 series
Rebuilt wastegate ready to receive the RUF 935 type boost controller
Stage 8 Exhaust locking nuts
Light weight adjustable cam gear
Bosch knock sensor for a used Turbo XS knocklite
Boost line for VDO boost gauge
Resurface flywheel
Rebuilt clutch
Resurface 915 Alu pressure plate
Hi-Torque starter
New plugs
New wires
New cap and rotor
K&N cone air filter
New oil filter
New belts
Replacing the air/fuel unit to turbo boot
Replacing Alternator
Removing the A/C and cutting bracket
And prepping for the 951 intercooler piping
1980 931S
Joined: 01 Jul 2004 Posts: 3155 Location: Eau Claire, Wisconsin
Posted: Sun Mar 24, 2013 2:41 pm Post subject: |
Shit, if I would've seen this earlier I have a turbo rubber boot that is in perfect shape to replace the one you have with a leak. _________________ [This Space For Rent] |
Posted: Sun Mar 24, 2013 8:54 pm Post subject: |
No worries, I have a replacement one already.
Thanks _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Mon Mar 25, 2013 5:43 am Post subject: |
Bad news, the crack is also visible from the inside
Can this be fixed or should I replace it?
1980 931S
Posted: Mon Mar 25, 2013 7:44 am Post subject: |
You can fix that, take small grinder, and groove the crack, then heat it in your oven to 500 degrees, and then weld it with a high nickel content arc welder rod. Then, put it in a box with sand on the bottom, then cover it with more sand, then forget about it for a few days as it cools. Many write-ups on this process on the board if you need more information. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Mon Mar 25, 2013 7:50 am Post subject: |
Grenadiers wrote: | You can fix that, take small grinder, and groove the crack, then heat it in your oven to 500 degrees, and then weld it with a high nickel content arc welder rod. Then, put it in a box with sand on the bottom, then cover it with more sand, then forget about it for a few days as it cools. Many write-ups on this process on the board if you need more information. |
Thank you for the info
Now I need to find a good local welding shop _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Mon Mar 25, 2013 8:09 am Post subject: |
Be careful there, the Porsche cast iron is a higher quality than most American manifolds that they might be used to. Don't let them MIG weld it for example. _________________ '83 944 Track car.
Posted: Tue Mar 26, 2013 2:23 am Post subject: |
Sweet, I just found someone to fix my exhaust manifold.
He as done many and he is using the same process as described above. _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Fri Apr 05, 2013 10:06 am Post subject: |
I picked up the clutch/ flywheel and 915 pressure plate from the shop at the end of the day with new release and pilot bearings.
Here’s some before and after shots:
Clutch disc:
Flywheel:
915 Pressure plate:
1980 931S
Posted: Thu Jul 25, 2013 10:01 pm Post subject: |
My latest ebay found for my GTS clone just came in the mail.
1980 931S
Posted: Tue Aug 06, 2013 7:00 am Post subject: |
How I plan to connect to the 951 intercooler
1980 931S
Posted: Tue Aug 06, 2013 8:38 am Post subject: |
Some body progress
-hood scoop
-944 fenders
-GTS front bumper
1980 931S
Posted: Thu Aug 08, 2013 2:19 am Post subject: |
Finally got some work done on the car this morning.
I removed 55lbs worth of crap, rotten under carpet from the front of the car and sticky rubber layer from the truck.
Also remove the non-working and unwanted A/C, 45lbs.
This stuff is free + shipping (unknown condition)
Then I loaded the front bumper with signal, driving light and modified 944 euro bumper rubber.
1980 931S
