ThomasJoseph315 Guest
Posted: Thu Jul 11, 2013 12:27 pm Post subject: Auxiliary Air regulator,.. bad? |
Shouldn't this be more open then this is this was placed in the fridge for 20 mins? It also measures 44.5ohms, book says should be 30ohms
scm924s
Posted: Fri Jul 12, 2013 3:28 am Post subject: |
Thanks for that post!
I thought it was supposed to be more open then that when it's cold? I didn't know you could adjust it, so I just opened it a bit more and stuck it back in the fridge. Lets see if this does anything, it did open a little more. |
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Mon Jul 15, 2013 2:21 am Post subject: AF |
You are on the right track. Then put 12V to it and it should close. There is a metal coil inside with 12V on it it heats up and closes the valve. _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
Julian
Posted: Sat Jul 20, 2013 8:53 am Post subject: |
They can be rebuilt. The 30 ohms is what you want to get to. The lenght of wire coil inside determines the time it takes too shut off the air flow. Coated wire won't work. Like electomagnet wire. I got some stuff from a co. who makes wire for NASA. 1 inch equals 1 ohm. Double coating of wolven fibreglass. A couple dollars a foot. The most difficult part is getting the halves apart. I've done several for folks on the forum.
They do get quite dirty over time. |
Posted: Sat Jul 20, 2013 4:48 pm Post subject: |
| that bright part is just the flash reflecting the oily surface, that's not the metal part. So that little opening is the largest opening it gets. Shouldn't it get more open then that? |
scm924s
