Front suspension refurb parts list
kcoyle
PostPosted: Fri Dec 07, 2012 5:58 am    Post subject: Front suspension refurb parts list Reply with quote
I am going to collect the parts for a front suspension refurb on my late 931. The front struts and the tie rod ends have been done recently by PO.
I have newly rebuilt calipers and fresh /pads/fluid/brake hoses. Wheel bearings are good. I will eventually order the parts below and paint the A arms.
Front and rear A arm bushings
Ball joints
inner and outer sway bar bushings.
Any other WYIT jobs I should be thinking about?
PostPosted: Fri Dec 07, 2012 6:21 pm    Post subject: Reply with quote
Inspect inner TREs. Inspect steering ujoint. Clean and lube steering column bearing. Inspect rack boots. Grease rack. Verify rack adjustment. Seam weld and powder coat a-arms. While wheels are off, clean thoroughly and inspect for cracks. Inspect brake bleeders for caps. Buy new locking nuts for crossmember-to-control arm bolts. Inspect O2 sensor wiring, insulation around plug at cross member. Replace O2 sensor if age unknown. Check tightness of all turbo fasteners.
kcoyle
PostPosted: Fri Dec 07, 2012 11:41 pm    Post subject: Reply with quote
Thank you sir, excellent list.
While looking at the PET I saw that the inner TRE is the whole TR. I did some research and came across this PN from an old post of yours
for the inner TRE
Autohauzaz 191419804AMY
http://www.autohausaz.com/search/product.aspx?sid=m3i2gg55nimhn2fnztq5boes&partnumber=191419804AMY
2 of these would be correct for my car, yes?
j03k64
PostPosted: Sat Apr 20, 2013 3:40 am    Post subject: Reply with quote
I have 1980 and am having a hell of a time finding control arms (A-Arms) for it. I called Paragon yesterday who carries arms for later models, but would require modification and welding. I'm posting because I've heard A-Arms from VW's fit, however, no one seems to mention years part numbers or anything useful regarding the cross over - I checked the 'cheaper parts alternatives' post, but the parts for the Golf I are unavailable in the States.
Anyone know where I can find new control arms for a 1980 (or earlier) that don't need modified? Or are we just screwed any buy the newer ones, cut the end bit off and seam weld it back onto the end of the control arm? Please advise! Cheers!
1979 Porsche 924
1980 Porsche 924
PostPosted: Sat Apr 20, 2013 5:25 am    Post subject: Reply with quote
Are you interested in used ones? Do you have a front sway bar?
Kenodog
PostPosted: Sat Apr 20, 2013 12:48 pm    Post subject: Reply with quote
You can buy new front control arms from Blackforest Industries for about $21 each. Remove the old ones and zip cut the old sway bar brackets off then have them re-welded onto the new arms. Stich weld the seams while you are at it and paint/powder coat. Voila,new arms for less than a hundy...
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Kenodog
PostPosted: Sat Apr 20, 2013 1:13 pm    Post subject: Reply with quote
oops,seems they have gone up since I last bought them..
http://store.blackforestindustries.com/mk1coarba.html
1981 931, Sabine
2024 KLX300
2024 KLX140
!tom
PostPosted: Sat Apr 20, 2013 4:39 pm    Post subject: Reply with quote
As discussed in that thread, the only difference between the left and right is in the included tie rod end, which doesn't fit our cars anyway.
However, even though it does fit, you can turn the steering wheel too far, which can cause issues, because the stops on the rack don't fit with those inner tie rod ends.
78 924 NA
5-lug
j03k64
PostPosted: Tue Apr 30, 2013 1:37 am    Post subject: Reply with quote
I would prefer new ones, but if you have a good set of used ones please send me a message! Options would be good right now!
It appears the previous owner parked the car in the grass for a long period of time causing the control arms to rust. I wouldn't even consider driving it on the road. The bit that needs seam welded on is shot on the drivers side and in fair - condition on the passenger side. The control arm on the drivers side is bent on the back half, which might explain why the front clip of the car appears to be pinched - maybe he ran it straight into a curb to get that kind of damage? It appears to be solely isolated to the control arm. Have a look!
I'm assuming I will have to custom make the brackets attached to the control arm from steel plate and seam weld them on considering mine are shot?
1979 Porsche 924
1980 Porsche 924
PostPosted: Tue Apr 30, 2013 1:57 am    Post subject: Reply with quote
Holy chit!!! How's the front crossmember? I have a set of used control arms that are in much better shape, just a little surface rust. From a 931.
j03k64
PostPosted: Tue Apr 30, 2013 2:59 am    Post subject: Reply with quote
Haha! I told you it was bad mate =) I think he ate a curb, there are abnormal dents in the floorboards, the front clip appears to be slightly pinched (body lines just need adjusted) and obviously the control arm took the brunt of it.
The front cross member is straight thankfully. Can you send me photos of the control arms you have Grenadiers?
1979 Porsche 924
1980 Porsche 924
PostPosted: Tue Apr 30, 2013 9:59 am    Post subject: Reply with quote
yeah, I'll try to remind myself to do that tomorrow1
agfisher
PostPosted: Tue Apr 30, 2013 10:17 am    Post subject: Reply with quote
Holy rusted metal, Batman!
1977 924 N/A Martini Edition
Kens_74_911s
PostPosted: Wed May 01, 2013 10:00 am    Post subject: fixit Reply with quote
j03k64
This should have been a fresh thread I sent you some PM's
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
PostPosted: Wed May 01, 2013 10:18 am    Post subject: Reply with quote
If none of those a-arms workout I have a pair from a 944 that are in pretty good shape I'll let go pretty cheap. They do need new ball joints but other than that they look good.
