xanderdeg
Joined: 08 Jul 2012 Posts: 286 Location: Vancouver, BC, Canada
Posted: Tue Apr 23, 2013 10:53 am Post subject: What oil should I use? |
| Doing my spring oil change within the next couple of days, just wondering what viscosity to use for the spring/summer months? I'm currently running 10w30 non synthetic oil. |
Posted: Tue Apr 23, 2013 1:24 pm Post subject: |
!tom
Posted: Tue Apr 23, 2013 1:43 pm Post subject: |
I use 20-50 dino juice year round. _________________ 78 924 NA
5-lug |
xanderdeg
Posted: Tue Apr 23, 2013 1:50 pm Post subject: |
| Synthetic? I hate to bring it up, but would regular oil with the same viscosity be pretty much the same? |
!tom
Posted: Tue Apr 23, 2013 2:13 pm Post subject: |
Dino juice means not synthetic.
It depends on your motor. Mine uses oil, so synthetic would be way too expensive. It's also old and tired, so thicker oil makes sense.
Synthetics are a no-brainer in a turbo motor. Synthetic and conventional are NOT the same, but conventional is good enough for many applications. _________________ 78 924 NA
5-lug |
txjake
Joined: 17 Feb 2007 Posts: 395 Location: Oklahoma City OK
Posted: Tue Apr 23, 2013 2:45 pm Post subject: |
Brad Penn is very good. _________________ 1978 924, aka The Red Rocker |
Posted: Tue Apr 23, 2013 3:10 pm Post subject: |
| xanderdeg wrote: | | Synthetic? I hate to bring it up, but would regular oil with the same viscosity be pretty much the same? |
No. If you want to run dino I would not go 5w40. _________________ Toofah King Bad
CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Tue Apr 23, 2013 11:04 pm Post subject: |
20-50 brad penn is what i use on my cars. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Posted: Wed Apr 24, 2013 12:28 am Post subject: |
You wanna see something funny check out the oil threads on Pelican. . .people get seriously pissed off. _________________ Toofah King Bad
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 471 Location: Ontario Canada
Posted: Wed Apr 24, 2013 12:49 am Post subject: |
I just put the Penn 20 - 50 in my car last weekend.
I would tend to stay away from the Synthetic unless it has been used for a while before. Or if you have just done a motor rebuild and are starting from scratch oil wise. I would probably use a high mileage oil as well.
just my thoughts. I went with Penn as my car will be tracked a bit this summer. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
joemac
Posted: Wed Apr 24, 2013 8:50 am Post subject: |
| !tom wrote: | | I use 20-50 dino juice year round. |
Yup. No more oil light/buzzer troubles (several VW's). _________________ Race car: my favourite palindrome.
Porsche: my favourite race car. |
xanderdeg
Posted: Wed May 01, 2013 1:30 pm Post subject: |
Put 20 50 in yesterday and IT'S TOO THICK!
Idles at just above 2bar when warm (not that bad)
Cruising on the highway at 3k rpm reads 5.8bar (pretty damn high)
Above 3k rpm it goes up to about 6.3bar and then stops ascending.
Thinking I'll go out and buy some 10 30 since that seemed to work well before. Maybe some 10 40.
Anybody want to buy some barely used 20w 50 Castrol dino juice?  |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Wed May 01, 2013 5:56 pm Post subject: |
I am not an expert, but would be really happy with those numbers.
I am running the same weight oil and get the same numbers. _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Posted: Thu May 02, 2013 12:20 am Post subject: |
Those pressures are good per FSM. Plus, they will go down after a few heat cycles. _________________ Toofah King Bad
xanderdeg
Posted: Thu May 02, 2013 3:41 pm Post subject: |
Hmm, they seemed a little high to me. But I probably know less than you guys do
10 30 gave me very different pressures that seemed a little more "comfortable" (4bar at 3krpm on the highway. Idling at 1bar.)
I'll see how it goes. Thanks guys! |
