Mudd
Joined: 27 Aug 2012 Posts: 78 Location: Cincinnati,Ohio
Posted: Fri Apr 19, 2013 9:40 am Post subject: AAV |
Where can I buy a AAV for a 1978 924 _________________ 1978 924
1987 944 |
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Sat Apr 20, 2013 2:42 pm Post subject: |
| OK, I'll ask. 68 people read this and no one posted. So what is an AAV? |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Sat Apr 20, 2013 4:41 pm Post subject: |
AAV= Auxiliary Air Valve.
It is an air valve that opens for a cold start and gradually closes over 5min during warm up.
New, they have become very expensive. _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
!tom
Posted: Sat Apr 20, 2013 4:44 pm Post subject: |
When I looked into this a while ago, the AAV for a 924 was quite expensive.
I'd suggest going for a cheaper AAV from another car (pick which one you want, as long as it's compatible with your hoses and connector). The differences will be related to engine size, so the closer to a 2 litre engine the better the fit will be.
An AAV from a smaller engine will have a smaller hole. Just drill it out a bit so its the same size as your current one and you'll save yourself a lot of money. _________________ 78 924 NA
5-lug |
joemac
Posted: Thu Apr 25, 2013 12:04 pm Post subject: |
What's wrong with yours?
Or, are you missing one?
They usually fail due to crud buildup in the rotary valve end, which is easily cleaned with a can of spray carb/choke cleaner. _________________ Race car: my favourite palindrome.
Porsche: my favourite race car. |
KDJones2000
Posted: Thu Apr 25, 2013 11:34 pm Post subject: |
I have one if you still need it. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
