What is this thing and what does it do? with pics
Karpaazio
PostPosted: Mon Nov 19, 2012 10:16 am    Post subject: What is this thing and what does it do? with pics Reply with quote
what is this and what does it do?
Is it possible to eliminate it or will it do something
Thanks, Kalle
Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver
PostPosted: Mon Nov 19, 2012 10:34 am    Post subject: Reply with quote
Auxiliary Air Valve.
Adjusts idle based on temperature and time.
You don't want to eliminate it.
daniel
PostPosted: Mon Nov 19, 2012 11:59 am    Post subject: Reply with quote
I have removed mine to no ill affect
1989 944 Cabriolet
PostPosted: Tue Nov 20, 2012 12:43 am    Post subject: Reply with quote
Generally pretty warm in Syndey, no?
Bockscar
PostPosted: Tue Nov 20, 2012 7:52 am    Post subject: Reply with quote
I've removed the IAC's on older Jettas which perform a similar function as the Aux Air Valve. Generally, they are helpful if you're looking to use the AC because engaging the compressor typically reduces idle speed. I see no reason to remove the aux air valve but if you really want to, crank up the idle a bit before you do.
Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped
Karpaazio
PostPosted: Tue Nov 20, 2012 7:57 am    Post subject: Reply with quote
Thanks for your answers guys! Older friend of mine has it removed and seems to work out just fine..
joejax
PostPosted: Tue Nov 20, 2012 8:28 am    Post subject: Reply with quote
I've thought about replacing mine with a solenoid that could be controlled from the cabin.
Also have thought about doing the same with the warm up regulator. Would really need to be in tune with your car to be reliable.
I got nothin'
Uhhh...you got any pics?
Bockscar
PostPosted: Tue Nov 20, 2012 8:34 am    Post subject: Reply with quote
The later model Bosch electronic IAC generally had oily air channeled into them (My old Saab and Jetta was like this) so after many years (like 10 years) of running this way, they would become sticky and would stop working properly. With my Saab, I just cleaned the sucker out real good with a tooth brush and carb cleaner and it worked again. I tried the same method on my Jetta but it didn't fix it so we removed it. We had to bump the idle up just a hair, and the idle ran a bit higher when the car was warmed up.
Regardless, if you're car is a daily driver and you want it to run nice and smooth, I'd just clean it up and leave it. If you're wanting to do something else, remove the thing, clean up the vacuum lines, and bump the idle up.
Brian
Julian
PostPosted: Fri Dec 07, 2012 1:37 am    Post subject: Reply with quote
Mine was bad. Caused the idle to function poorly. Sometimes adjusting around it started to cause more issues. Hard to find so I rebuilt mine. Now works well. The timing is right on with the closing. Finding the correct wire to rebuild with is difficult and a little expensive. OHMs are directly related to the wire length.
