BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Thu Aug 30, 2012 10:12 pm Post subject: |
I'll check it. The car starts up great and runs perfect for about 30 seconds to a minute. So I'm pretty sure AAV is doing it's job. It's the 1 min to 5 min. range that is pissing me off. _________________ 1980 924 NA
1982 931 |
Julian
Posted: Thu Aug 30, 2012 10:45 pm Post subject: |
Another thing I remembered was I had to replace the fith injector with a used one.
I went through this hell for several months and found several changes the PO had made to fix the idle. Including ONE misplaced vacume line. Finally I have the engine figured out and am stuck with a small wiring issue.
Great learning process, but frustrating. When you find it, post it I'd like to add it to my collection of "another place to look" |
scm924s
Posted: Sat Sep 01, 2012 5:24 am Post subject: |
The AAV should still operate from heat soak temperature from the engine if the power supply isn't operative, albeit not as effectively. Check it is operating by applying 12v to it for 20/30 secs. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
BionicBalls
Posted: Sat Sep 08, 2012 9:19 am Post subject: |
All fuel pressures are perfect, I've got spark. I tested compression: 215, 215, 215, 25.
That's the problem. Hoping it's just needing valve adjustment. Otherwise, I will be putting an LS motor in there. _________________ 1980 924 NA
1982 931 |
