dash16
Posted: Fri Apr 22, 2011 6:54 pm Post subject: Cabin gas smell |
Should I worry about gas fumes igniting in my cabin? Think a cell phone could set this off or merely the electronics in the vehicle would be enough?
How do I identify the leak and fix this issue? Thank you _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Fri Apr 22, 2011 8:47 pm Post subject: |
Must be leaking somewhere if you fear ignition Check this vid out for a little reassurance:http://dsc.discovery.com/videos/mythbusters-cell-phone-gas-station-minimyth.html
I get the smell when tank is full, but I've noticed if I take it easy through left turns until fuel level drops, it's not too bad. _________________ I got nothin'
Uhhh...you got any pics? |
Posted: Sat Apr 23, 2011 1:35 am Post subject: |
You should worry a lot if the fumes are coming from the engine compartment. There is a line coming off the fuel rail that was recalled by Porsche, and the whole system is under a great deal of pressure. IMO, all rubber fuel lines in the engine compartment should be replaced.
Many 2.5s have burned to the ground due to fuel line failure. _________________ Toofah King Bad
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Apr 28, 2011 10:46 am Post subject: |
Petrol fumes do have a fairly narrow range of concentrations they will ignite in. But it's not healthy for your lungs, never mind the chance of ignition.
I found that it's easy to overfill the fuel tank. If you do, the fuel is lapping at the vents in vapour system in the filler pipe. It's not supposed to do that. If you're used to filling to the third click on the bowser, teach yourself to stop at the first click in your 924.
Wade. |
mehall
Joined: 15 Dec 2008 Posts: 191 Location: Richmond, MO
Posted: Thu Jul 12, 2012 9:51 am Post subject: |
Rasta Monsta wrote: | You should worry a lot if the fumes are coming from the engine compartment. There is a line coming off the fuel rail that was recalled by Porsche, and the whole system is under a great deal of pressure. IMO, all rubber fuel lines in the engine compartment should be replaced.
Many 2.5s have burned to the ground due to fuel line failure. |
Rasta - so with what should I replace the fuel line? Mine does indeed need the deed done.
If you know of a kit or can point us to a parts list....
Thanks. _________________ Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org |
mehall
Posted: Thu Jul 12, 2012 1:16 pm Post subject: |
'94 Lexus LS400
www.kcws.org |
Carrera
Joined: 13 Nov 2009 Posts: 143 Location: Helsinki, Finland
Posted: Tue Aug 07, 2012 9:31 pm Post subject: |
I had the same gas smell problem in the cabin. My mech insalled a plastic cover from a newer 944 and sealed it off. No fumes in the cabin anymore. However, if I open the windows the fumes find their way in again... In my case there is gas dripping from the overflow pipe behind the back wheel even if the tank is only half full. This of course after spirited track driving or tight turns... Going to get a new bleeder valve installed. Lets see if that helps... _________________ 931 S2, 1981 |
!tom
Joined: 28 Aug 2006 Posts: 1930 Location: Victoria, BC Canada
Posted: Wed Aug 08, 2012 12:52 pm Post subject: |
Carrera wrote: | I had the same gas smell problem in the cabin. My mech insalled a plastic cover from a newer 944 and sealed it off. No fumes in the cabin anymore. However, if I open the windows the fumes find their way in again... In my case there is gas dripping from the overflow pipe behind the back wheel even if the tank is only half full. This of course after spirited track driving or tight turns... Going to get a new bleeder valve installed. Lets see if that helps... |
Sounds like a classic case of needing to drop the tank to replace all the fuel lines on top. You might even have a cracked tank; there's been some discussion about it.
Here's my saga (that includes links about the cracked tank) _________________ 78 924 NA
5-lug |
