Slotted Rotors
Dave
Guest
PostPosted: Sun Aug 05, 2001 2:39 pm    Post subject: Reply with quote
I have added slotted rotors to my car and I am happy with them. But I was thinking When rotors get stotted they lose some surface area so wouldnt it make your braking Worse????
MAS
Guest
PostPosted: Mon Aug 06, 2001 4:18 am    Post subject: Reply with quote
I think the main reason for his is to provide extra cooling under repeated hard braking conditions, as in racing. I should think that there would be some penalty involved too, like a reduced brake surface area. I should guess that this would be a trade off. But most discs I've seen like this are usually pretty large anyway.
-MAS
numbers
Guest
PostPosted: Sat Aug 18, 2001 7:51 am    Post subject: Reply with quote
The main reason for slotting the roters is for gas disapation, not cooling. As your pads heat up during braking, they give off gas just like wood in a campfire. This gas tends to build up between the rotor and the pad, reducing friction. Think of it as your brake pads hydroplaning. The slots in the rotor act as a path for the gas to excape, just as the grooves of a tire channel the water out to the side.
PostPosted: Tue Aug 21, 2001 5:03 am    Post subject: Reply with quote
Yeah, but they have an adverse effect in durability of the brakes; they act a little like cheese graters to increase pad wear rate. At least they won't make the rotors crack like cross-drilled!
I don't have anything fancier than stock rotors on my racecar, not legal to use cross-drilled or slotted rotors.
