BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Mon Dec 12, 2011 1:22 pm Post subject: Windshield Wipers |
In the next few weeks I will finally have the time to upgrade the heater system in the 924 to the 944 blower. In the process I was thinking of converting my wiper assembly to the 944 unit as well, but the early assemblies seem to be in short supply so instead I'm gonna service mine.
The problem I'm having is 2 fold:
1) the wipers are slow as shit even on full blast. I'm hoping greasing the transmission will help this.
2) my passenger side wiper keeps coming loose from the stud. I've tried replacing the bolt with one with a nylon lock ring, adding a lock washer, using lock tight, and taping and dying the treads to clean them up. Nothing seems to keep my passenger wiper fixed to the stud.
Any suggestions for problem 2? Is there some special washer or something that I may be missing?
If not, anybody got a good unit for sale? _________________ 1980 924 NA
1982 931 |
ksis
Posted: Tue Dec 13, 2011 12:05 am Post subject: |
I ill be curious if you decide to rebuild. I had the same issue with slow wipers.
Eventually I greased all connections with white lithium and the problem went away.
I would however like to see a motor tear own. _________________ 77 924
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin |
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Thu Dec 15, 2011 10:43 am Post subject: |
The wipers on my 924 are very slow as well. Went through with taking it apart (sorry, no pictures) and It looked brand new inside. you could literally see the thumb prints in the putty they put on the motor to balance it. No ideas as to why it's so slow. NOT buying a new one, ha! _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Posted: Thu Dec 15, 2011 11:26 am Post subject: |
Poor electrical connection to the motor.
Increase the amount of power the motor can draw and it will go faster.
Poor internal connections or poor lubrication of the bushings in the motor.
Pull the motor apart, clean it, make sure the brushes and commutator are clean. Clean and lubricate the bushings, make sure the commutator doesn't rub or bind. _________________ Stefan
BionicBalls
Posted: Thu Dec 15, 2011 12:36 pm Post subject: |
that will help it go faster, but any suggestions for the passenger side arm that doesn't want to stay tightened? _________________ 1980 924 NA
1982 931 |
Posted: Thu Dec 15, 2011 12:43 pm Post subject: |
Loctite? _________________ Toofah King Bad
BionicBalls
Posted: Thu Dec 15, 2011 1:55 pm Post subject: |
See OP. Tried it, lock washer, lock nut. Maybe a lock washer above and below the wiper arm? _________________ 1980 924 NA
1982 931 |
Posted: Thu Dec 15, 2011 2:56 pm Post subject: |
Aren't they splined onto the shaft? _________________ Stefan
BionicBalls
Posted: Thu Dec 15, 2011 8:57 pm Post subject: |
I think so, if that's the case... the splines are gone. _________________ 1980 924 NA
1982 931 |
ksis
Posted: Fri Dec 16, 2011 1:45 am Post subject: |
There is 2 924 in our local pick n pull, I can see if the stud is there and pull it for you. I think the stud is the same for the early VW's. I will chack that also. _________________ 77 924
64 Spitfire
76 TR6
04 Jetta
BionicBalls
Posted: Fri Dec 16, 2011 10:56 am Post subject: |
That would be awesome, the local junkjard crushed all the 924s and 944 a few months back. I'll let you know if I will need it. I'll be working on it after Christmas. _________________ 1980 924 NA
1982 931 |
AppleBit
