dgz924s
Posted: Sun Aug 07, 2011 5:06 am Post subject: Not sure what the part number is? |
Hello all, need some help....My A/C switch in the cabin has lost 2 of the 3 speeds for the fan and need a new switch or a working used one from anyone who has one available. I tried to find a new one but I have no part number to reference or even the exact name it is called?
FYI This is the same switch that turns on the A/C and to control the temperature of the air as well if this helps at all.
I will bet George has one if he sees this post.
Thnx!! _________________ Dal Glassinger |
camfella
Joined: 20 Jul 2010 Posts: 42 Location: Ottawa - Canada
dgz924s
Posted: Sat Aug 27, 2011 8:04 am Post subject: |
Yes it does, thanks!! _________________ Dal Glassinger |
camfella
Posted: Fri Sep 09, 2011 7:21 am Post subject: |
I found a spot to d/l the full catalog 924 online: http://www.nineapart.com/findpart.php
it is kind of a weird search control box, however I have grabbed the pdf's from here.
Cheers _________________ 1987 924s |
