Ozzie
Posted: Thu Jul 19, 2007 2:19 pm Post subject: Rear Latches |
I bought some rear latches of ebay and they were worse than mine.
The description said GOOD. Well they were only good for one thing.
Anyway I decided to have a good look at what fails on these.
Out with the 5mm drill bit
Well stuff me- how simple was that? So I did the same to the other one.
Looking at it, the crescent part is what wears out on the bottom and the left and right are intechangeable.
So I swapped the metal plates over, drilled out a clearance hole and countersunk one side and tapped a 6mm hole in the other.
Cleaned up the parts, greased and assembled.
(be wary of the spring- mine shot off to the nether regions of the shed)
Done- a new lease on life for the latch.
_________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
!tom
Joined: 28 Aug 2006 Posts: 1933 Location: Victoria, BC Canada
Posted: Mon Apr 25, 2011 2:55 am Post subject: |
Pictures have died. _________________ 78 924 NA
5-lug |
Ozzie
Posted: Mon Apr 25, 2011 2:22 pm Post subject: |
4 year old post- got no doubt
ended up buying new double latches when I went to the UK, never had a problem since. _________________ Porsche 924 1984 (UK import) NA
